  3. Transfering Routes to Garmin XT - SD Card
6 Posts 3 Posters 1.3k Views 1 Watching
  • John Forrester Offline
    John Forrester
    Hi, Is it possible when using the export function of MRA to my Garmin XT to store the route on to the SD card directly? Am I missing how to do it or is it not possible.
    Thanks any advice appreciated. John
    • John Forrester John Forrester
      @john-forrester
      Hi John, by default the gpx file goes to the XT.
      What you can do is: Save the route as (gpx 1.1 (Route, Track and POI)
      or
      Do NOT enable the MTP setting Mass Storage Device, then the XT will not be seen as a disk, but your SD card may be.
      If that does not work, then export the route via the connector and transfer the gpx file via the explorer.
      This for a Windows PC!
      For a Mac it is slightly different, search the forum if you have a Mac.
      John Forrester AWDC LAO 3 Replies Last reply
        @john-forrester
        or
        John Forrester
        @hans-van-de-ven-mra-master
        Thanks for that, I think i Had it set to mass storage option, I will try it they way you suggest.
        Thanks. John
          @john-forrester
          or
          John Forrester
          Just re tried it and my routes .tracks etc are on the SD card. Thanks. John
            @john-forrester
            or
            AWDC LAO Offline
            AWDC LAO Offline
            @hans-van-de-ven-mra-master A Mac from Apple is different, I always copy my files .ITN and .GPX(1.n) directly to the right map on the SD. ( simple and always working )
              John Forrester
              Hi, thanks for all the help its now sorted. Cheers. John
              • Hans van de Ven MR.MRA Hans van de Ven MR.MRA locked this topic on
              John Forrester
              John Forrester
              • How to share route with another member.
                Philip Verbeek
                Philip Verbeek
                701
              • Route doesn’t recalculate to my destination
              • No navigation instructions
