  2. Routes & Tracks
  3. How to have more than 200 waypoints?
7 Posts 4 Posters 2.3k Views 2 Watching
  • Kain
    Kain
    Kain
    Hello,
    I'm tracing motorcycle offroad tracks and TO fit to the path, I need to add a lot of waypoints. The problem is that I get very quickly to more than 200 waypoints and then the system block. Would you have a solution to bypass this limit?
    Thanks
    • Kain Kain
      Hello,
      Thanks
      @Kain
      No, 200 is the max
        If you need more than 200 waypoints, you do something wrong is my opinion.
        It seems you need so many waypoint because you try to force the map to do something it wasn't meant to do.
        Kain 1 Reply Last reply
        • M. Schrijver M. Schrijver
          Kain
          Kain
          Kain
          @M-Schrijver I'm doing offroad trace where standards route calculator are not following little path in the wood. SO I have to put toons of points to fit the road curves.
          And all off-road trace that you can find have way more than 200 waypoints.
          Sometime I get up to 800 waypoints.
          • Kain Kain
            @Kain
            Use the off road fuction in the toolbox
              When you want a track which follows the paths on the map, it is still possible you will have the 200 points limit. But selecting the "offroad" function is probably the best option/compromise.
              • Con Hennekens
                For offroad I think you should stick with using the track, and not try to make a route out of it. The only solution I see for now, is to do it in segments of 200 WPs, and combine the resulting tracks into one with a third party tool.
                Kain
                Kain
                • Beta Navigation V.6
                  41
                • MRA 6.0.0 515 – Removal of the "Navigate routes as tracks" option and problems with outdated road closures in HERE
                  Reinhard Punz
                  Reinhard Punz
                • Route overlay
                • Suggestie voor notitie teksten tijdens rijden
                  Albert van den Elsen
                • Versie 6 van Navigation Next app
                  superg
                  superg
                • Machtiging tot Fysieke Activiteiten
