  2. [Beta] The MyRoute-app
  4. Extra voices issue on Apple Play
4 Posts 3 Posters 67 Views 1 Watching
  • Larry Stayner Offline
    Larry Stayner
    When connected to Apple play and a turn comes up, I get a pre statement that says" Voice command apple communicate " before it gives the actual turning directions. It then says 'voice command" after the directions. It is like it is speaking a couple of lines of code instead of running them in the back ground. It has done this in the last two beta releases.
    • Larry Stayner Larry Stayner
      Corjan Meijerink Offline
      @Larry-Stayner that’s very strange. Haven’t heard of this as an issue before.
      Could it be an accessibility setting on your phone?
      • Jörgen Offline
        Jörgen Offline
        It looks like Voice Control is on.
        How do I disable Voice Control on iPhone?
        On the "Accessibility" screen, scroll down to look for the "Side Button" option and tap it. 4. On the "Side Button" screen, under "Press and hold to speak," you have the option to select whether pressing and holding the home button activates Siri or Voice Control or whether it does nothing at all.
        Larry Stayner 1 Reply Last reply
          Larry Stayner
          @Jörgen Sorry it took me so long to respond. The setting you are talking about is set to off.
          Larry Stayner
          Larry Stayner
          • Welke instelling
            1.1k
          • Navigatiescherm telefoon bevriest
            Leike Lodiers
            Leike Lodiers
          • opslaan naar plantomtom
            chris 18
            chris 18
            484
          • Seizoen sluitingen wegen
            PAT62
            PAT62
          • The slow death of Zumo...
            Thomas Schäfer
            Thomas Schäfer
          • New Zealand Touring Group
          • Rejoining routes
