  4. Which map is used on mobile
3 Posts 2 Posters 989 Views
  • Csaba Trenger
    Csaba Trenger
    Csaba Trenger
    Hi,
    I wonder, which map is used in the new mobile App MyRoute-app. As I see, I can chose a map in settings when now route is planned or loaded, but when there is a route in the app, it seems to be the Here map, and I don't see if I can change it anywhere to OSM or Tom-tom.
    It is also a question, which map is downloaded for offline routing.
    Thank you,
    Csaba
    • Csaba Trenger Csaba Trenger
      Hi,
      Thank you,
      Csaba
      @Csaba-Trenger That would be HERE! 🙂
      In the first screen you see when opening the app you can choose any map layer you like (as in the website) but when navigating, you use HERE. The offline maps are therefore also HERE.
      This because the app is built on HERE software.
      Csaba Trenger 1 Reply Last reply
        Csaba Trenger
        Csaba Trenger
        Csaba Trenger
        @Corjan-Meijerink Thank you, it is clear now 🙂
        Csaba Trenger
        Csaba Trenger
          27
          Vince Hyde
          Vince Hyde
          11.4k
          b0hd1
          b0hd1
        • Probleem met eigen Stay
          Albert van den Elsen
        • POI functie 'strict'
