  4. I would like to know...
3 Posts 2 Posters 64 Views
  • ferrand24gmail.com
    ferrand24gmail.com
    ferrand24gmail.com
    Does the navigation work independent of wi-fi or data?
    Unless I am doing something wrong I find that when out of wi-fi range or no data signal It just don't work.
    Once again I plotted a route, downloaded it for off line use and all the regional maps are also downloaded. If I stop the navigation at any point during the trip it will not resume, "could not calculate route". Well, it seems to me that the route has already been calculated I've been using it without problem for 50kms.
    This seems such a fundamental requirement that in the event of it not working, the whole thing is effectively useless.
    My Garmin and my BMW sat nav both work in the absence of wi-fi and data so as a member of the public I would see little value in buying a system which doesn't.
    Please tell me I am missing some vital point and tell me how to put it right.
    • ferrand24gmail.com ferrand24gmail.com
      @Roger-Doidge have enable the offline mode within the Navigation settings (functional)? The app should work without internet in that case.
      There is an issue specifically with resuming navigation when you don't have internet (and did have it when starting navigation) - that is fixed in the upcoming 4.0.3 update 🙂
      ferrand24gmail.com 1 Reply Last reply
        ferrand24gmail.com
        ferrand24gmail.com
        ferrand24gmail.com
        @Corjan-Meijerink OK thanks. I look forwards to the update.
        ferrand24gmail.com
        ferrand24gmail.com
        • Map Layers
          Martin White
          Martin White
          Michael 2v
          Michael 2v
