Message "card offline"
even with an available network connection, when the "offline navigation" parameter is selected in the functional menu, by selecting "offline map" MRA displays the message to go online ?
I don't quite understand what that means, The message is a contradiction
@Calibos while offline navigation is enabled the entire navigation module is restricted from any internet connection.
Offline maps require internet for any interaction and therefore cannot be viewed while offline mode is enabled
@Corjan-Meijerink please review your answer. Is it correct?
I'm ok with this but then the message in French should be "offline maps cannot be downloaded or updated with the offline option selected"And the behavior of the route module should then also not allow access to online routes but only to the download folder
@Calibos, Offline maps and Offline navigation are two separate things. The use of offline maps does not implicate there is no internet access for others things then maps (trafic info and address lookup for example). Also The Main screen of the app is not the navigation module. Browsing the online folders happens when the navigation module has not been started yet.
In fact my sugestion only referred to the displayed message "Offline maps cannot be used when the application is configured to be offline".
I don't know if it's a translation problem but in French it's like saying "you can only use offline maps if you're online" it's a bit
of a misinterpretation.
But in the end when we found the solution it's a detail. -
But in the end when we found the solution it's a detail.@Calibos ah thanks! Yeah, Iβll edit the translation
Itβs more like you cannot manage offline maps when offline mode is enabled
But in the end when we found the solution it's a detail.@Calibos, yes, good point.
With your input, this post could be even better π
