  4. Screen Layout
Screen Layout
1 Posts 1 Posters 59 Views
  • Angelo Greco
    Angelo Greco
    Angelo Greco
    Hello
    This may have been mentioned previously, I am having trouble viewing elements of the display.
    I have a six inch phone and use it in landscape mode. I find the distance to next junction text and Roundabout exit numbers far too small to see at a glance. Especially with slight vibration on the phone screen.
    Another issue is viewing the screen in bright sunlight.
    I do not use helmet speakers and have the voice prompts turned off. I depend on the visual turn indication, which as well as being small as mentioned above, I find that the white on blue can become washed out in bright sun.
    I have used another application that uses white symbols and text on a black background which I find remains more visible in bright sun. Also the size of the text/symbol box is much larger. In fact the information window takes up about a quarter of the screen width so text is large and clear and can be spotted at a glance. The fact that the map area os reduced is not a problem as I only use the map should I get lost or need to take a detour.
    Would it be possible to have the background and foreground colours and size of the information boxes selectable by the user?
    This would be a big improvement for me.
    Thank you
    Angelo Greco
    Angelo Greco
      John Matthews 0
      John Matthews 0
