  3. Suggestion: When converting track, make it possible to let it be a cycle route
2 Posts 2 Posters 537 Views 1 Watching
  • reinier.beenengmail.com
    When converting a track to a route, I reguarly want to create a bicycle route. However, MRA converts it always to a route for motorways. Afterwards you can change this to a cycle-route, but then you have to move all route points to cycle roads. It so much less time consuming when MRA already puts the generated route points on cycle roads.
    The functionality is already there because when I create a new route from the menu, I can set the driving mode to cycle.
    So the suggestion is to create the possibility to generate a cycle-route based upon a routetrack (which off course is already a cycle-track)
    • Rob Verhoeff
      @Reinier007 The map used for navigation is the Here map. When designing bike routes, it's better to immediately make use of the OSM map. You can convert the routetrack, but then you have to switch to the OSM-map and check al waypoints for there exact position on the road. Although you won't have turn-by-turn navigation when cycling, it's very easy to follow the line. All your shaping and via points will also be displayed. Apparently, the Here map is suitable for turn-by-turn navigation while cycling in some countries, but that's not the case for the Netherlands.
      • Question on Beta access
        Jeroen ekkel c
        Jeroen ekkel c
      • Add "Upload File"
      • Totaaltijd veranderd niet
        Gerard Caspers
        Gerard Caspers
        BMcG
        BMcG
      • The route is not shown on the PDF route map
