  4. First CarPlay Test
First CarPlay Test
25 Posts 6 Posters 263 Views 1 Watching
    @Fabrice-Leijs het beste is om een app pas op te starten als CarPlay verbonden is. We zijn hard aan het werk om dat probleem op te lossen.
    Fabrice Leijs
    Fabrice Leijs
    Fabrice Leijs
    @Corjan-Meijerink Bedankt voor de tip
      Just one request, if the post starts in English, can you please continue writing in English? Thank you!
      Slechts één verzoek, als het bericht in het Engels begint, kunt u dan alstublieft in het Engels blijven schrijven? Bedankt!
        Good morning,
        the first CarPlay test was done yesterday for a short trip.
        You first have to get used to starting the tour on your mobile phone. This worked well so far and the tour started normally. After a few kilometres, however, the app crashed at a junction.
        I think the crash data is transmitted to you via Test Flight.
        By the way, that was not the only crash, it happened again on the way back.
        But you could start the route again via "Last route". However, the starting point was then waypoint no. 1 and the destination no. 2, but you could skip waypoint 1 and the route continued normally.
        What else happened can be seen in the pictures. The additional information was lost and could only be seen on the mobile phone.
        But what worked very well were the announcements and hints. This worked well with the radio sound. The radio was turned down and the sound came back after the announcement.
        Test Hardware: iPhone X 16.3.1 and CarPlay Radio in the Seat Arona (VAG Type)
        The good thing is that screnshots are made for both (mobile phone and Carplay display).
        As you can see, additional information is lost.
        @Jörgen said in First CarPlay Test:
        @Corjan-Meijerink I am coming back to this because the current version (4.0.2. - 202) is not working well (as the version before).
        For some reason, the old issue from before March is back in the current version.
        Radio is still not coming back after navigation announcement and speed warning.
        Please reactivate the function build in the March 25th version.
          If only it was that easy 😉
            #25
            Ok, so it is more complex then before?
            Anyway you know now and I will wait patiently. 😕
            Albert van den Elsen
            Bart De Medts
            Bart De Medts
            Walter Coady
            Walter Coady
            Fabrice Leijs
            Fabrice Leijs
              Axel Lange
              Axel Lange
            • In het kort......
            • Route probleem
              Jack 13
              Jack 13
              162
