  2. Routes & Tracks
  3. Default Map for Imported Routes
11 Posts 4 Posters 2.6k Views
  • Dae 0
    Dae 0
    Dae 0
    Hi,
    I've done a search and can't find the answer to this problem.
    I have several hundred routes which I need to move across from BaseCamp. I'm OK with having to export each folder list from BaseCamp and import them into an MRA folder, but my problem is that the imported routes are all defaulting to the Open Street Map. This means I'm having to manually open each route and change the map to Here Maps.
    Is there a way to either change the default map for imported routes, or bulk change the map for all my routes? I have my default for new routes set as Here, but that setting isn't honoured for imported routes.
    Thanks
    Dae
    • Dae 0 Dae 0
      Hi,
      Thanks
      Dae
      Herko ter Horst
      Herko ter Horst
      Herko ter Horst
      That seems like a bug to me, there is a setting to select a default map for new routes, but it does not seem to apply to uploaded routes, just routes you start from scratch within MRA.
      Dae 0 1 Reply Last reply
        Dae 0
        Dae 0
        Dae 0
        @Herko-ter-Horst said in Default Map for Imported Routes:
        That’s my feeling too. I’m not relishing the prospect of manually going through several hundred routes to change them.
        • Dae 0 Dae 0
          @Dae-0 I’ll check if this is a bug on Monday 🙂 If so, I’ll fix it and report back here! So feel free to wait a bit before importing all your routes 😉
          Nick Dawson Dae 0 3 Replies Last reply
            Nick Dawson
            Nick Dawson
            Nick Dawson
            @Corjan-Meijerink O am not sure if it is a big or something that simply has not been thought through.
            For as long as I have been using MRA, this has been the case.
            If there is a fix them I too will be delighted!
              Dae 0
              Dae 0
              Dae 0
              @Corjan-Meijerink said in Default Map for Imported Routes:
              Thanks. That would save me tons of work
                Dae 0
                Dae 0
                Dae 0
                Hi. Did you get chance to investigate?
                • Dae 0 Dae 0
                  @Dae-0 You just beat me to it 😉
                  It was the last item I wanted to do today and I just deployed the fix! Your imported routes should now respect the default map you've selected 😏
                  Good luck importing all your routes!
                    Dae 0
                    Dae 0
                    Dae 0
                    Thanks for the speedy response. I’ll give it a whirl tomorrow
                    • Dae 0
                      Dae 0
                      Dae 0
                      Just an update. The fix has sorted it now so imported routes use my default Here map
                      • Dae 0 Dae 0
                        @Dae-0 Happy to hear! 🙂
                        Dae 0
                        Dae 0
                        Nick Dawson
                        Nick Dawson
                        Herko ter Horst
                        Herko ter Horst
                        • Custom POI color and icons
                        • File en omrijden
                        • File / Creation date
                          Robineke
                          Robineke
                          310
                        • F005 Menu covered
                          13.6k
