  4. Skip waypoint selection
5 Posts 2 Posters 163 Views
  • Robineke
    Robineke
    Robineke
    Four things I want to bring to your attention:
    Pressing the top right waypoint where I am drive to let me only skip the first next waypoint. It would be nice to have first 3 or 5 comming waypoints so you can select which one to skip.
    Selecting the menu, three dots right bottum, skip waypoint gives the same option. There I would expect a larger list of selectable waypoints.
    When pressing skip waypoint it gives only a number. I would prefer my description. F.e. Skip "Fuel station Arnhem". Then I know what I skip. Number are not memoriesed by myself for the whole route.
    Great succes so far, thanks.👍
    • Robineke Robineke
      @Robineke Thanks for your feedback!
      • This button will only allow skipping the first by default. If you want to skip to another, simply long press this waypoint on the map. In a future update you can also do this from the waypoint list (which still needs to be created)
      • Same answer as above
      • Good suggestion!
      • Is there a fourth point? 🤔
      Cheers!
      • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
      • Corjan Meijerink Corjan Meijerink unlocked this topic on
      • Robineke
        Robineke
        Robineke
        First bullet of Corjan. Indeed you are correct however long press will skip several waypoints instead of one few waypoints further. In that case a list as you indicated is more convinient and will do.
        No fourth point. I started the post with four but in the mean time one was solved. Sorry for inconvinience.
        Thanks again for excellent work.
        This subject may be closed.
        • Robineke Robineke
          @Robineke Thanks for your reply 🙂 The waypoint list will be created for sure!
          Robineke 1 Reply Last reply
            Robineke
            Robineke
            Robineke
            @Corjan-Meijerink I have seen the video which also explains the skipping of waypoint AND reinstating them. This is a great contribution.
            My points have now become less relevent although it might be handy to skip some by my co-pilot during driving (without a stop) and extensive work.
            Robineke
            Robineke
