  4. GENERATOR I: some german translations
2 Posts 2 Posters 37 Views 1 Watching
  • Ronni
    Ronni
    Ronni
    Checking some german translations, starting with GENERATOR:
    MyRoute overview side:
    It is not clear enough that routes are generated by the system in the generator. Therefore, I would suggest the following adjustments:
    Neue Route replace by --> Neue eigene Route erstellen
    Generator replace by --> Neue Touren generieren lassen
    roundtour settings:
    When selecting Scenic Roundtour erstellen or Scenic Route erstellen, almost the same information appears 3 times !!!
    1. Instead of the adaptable heading “Scenic Rundtouren/Routen erstellen”, I would generally adopt the selection label from the previous menu item as the heading for both variants: Neue Touren generieren lassen
    2. I wouldn’t use the 2nd description
    3. I would display both sub-items, let them be selectable (button) and rename them as follows:
      Eine Scenic Rundtour erstellen replace by --> Neue RUNDTOUR erstellen lassen
      Eine Scenic Route erstellen replace by --> Neue ROUTE erstellen lassen
    4. I would write RUNDTOUR und ROUTE in capital letters to better detect the differences
    Eingabe Start / Ziel
    When determining the Start and Finish of the scenic routes, I would suggest the following adjustments:
    Finden Sie eine Adresse oder Ort replace by --> Startpunkt festlegen
    Finden Sie eine Adresse oder Ort replace by --> Zielpunkt festlegen
    When defining Rundtour and Routen
    The plural of Vermeidung is not often used in German, so I would suggest the following:
    Allgemeine Vermeidungen replace by --> Allgemein zu vermeiden:
    Vermeiden Sie bestimmte Straßen replace by --> Folgende Straßen sind zu vermeiden:
    Note: Aren't toll roads roads as well? Shouldn't they be listed in the second selection?
    Could Pässe be listed in the first selection? For trucks or motorhomes e.g.:
    greetings
    Ronni
    Samsung Galaxy A56 5G
    Android 16
    One UI Vers. 8.0
    Carpuride W712D
    Silverfox BT Cntroller H1+
    • Ronni Ronni
      roundtour settings:
      greetings
      Ronni
      @Ronni
      Danke @Ronni, die Programmierer werden es übernehmen.
      Ich werde dieses Ticket jetzt schließen
      • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
      Ronni
      Ronni
      • Kaart niet zichtbaar
        209
        22
        41
        353
      • Xpert overlay not clear
      • Google maps
        Ed Bos 0
        Ed Bos 0
        206
        Jaap van Maanen
        Jaap van Maanen
        140
        Corrado Miniati 0
        Corrado Miniati 0
        286
