  2. MRA Routeplanner Next Beta
  4. F026 WebPlaner Old to New Synchronize
3 Posts 2 Posters 29 Views 2 Watching
  • Hubert Thoring
    A big scare! ?
    If I change the copy of the library created after the first synchronization with the old WebPlaner in the new Beta WebPlaner and then move routes and maybe also change it, it is okay so far.
    However, for the better presentation, I had now introduced an A_ B_ C_ to Z_ in front of the folders in the Beta WebPlaner. So it's better for me now.
    I had a problem today, because after restarting the WebPlaner Synchronize I now have partly old folder structures with subfolders but all without routes. However, this does not apply to all folders .....
    Sorry I can no longer recommend such a second synchronization, it is best to deactivate the switch after a first synchronization.
    Two examples:
    Example 1: Picture 1 - 3
    • The folder "1980 - 2026 Archived" was first in the main directory, which I pushed without thinking carefully to where I actually had it before. Somehow under B_ .... /...
    • When I looked closer, I got scared, then I thought it was already under B_ .../ A_Routen_Freunde / and there he was and that with content.
    Solution:
    • I then deleted the folders without content, see picture 2 (B).
    Example 2: Picture 4
    • The folder in picture 4 with the C_ in front of it is the one from the first synchronization (new) there I only added the C_. Now after the second synchronization I see the same folder (ALT after the second synchronization) that is empty.
    iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
    • Hubert Thoring
      wrote last edited by
      Sorry, I can't describe it better, I don't know yet if there's more confusion, I'll take a closer look at that tomorrow.
        Sounds perfectly fine. Don’t look into it closer.
        The sync isn’t built to support you completely renaming things in both environments.
        After an initial sync you are indeed good to go.
        As you discovered yourself, nothing went wrong. It just looked slightly confusing as because of the renames it could not locate stuff.
        • Corjan Meijerink Corjan Meijerink locked this topic
          JP d
          JP d
          Guzt
          Guzt
          1.8k
          2.5k
        • Beta abonnement
          BMW1300GSA
          BMW1300GSA
        • SilverFox Controller C2
          Hans Lamers
          Hans Lamers
        • Nieuw startpunt
          Jeroen ekkel c
          Jeroen ekkel c
          1.3k
        • Tracklog to Routetrack Conversion & Creation
