  2. Routes & Tracks
  3. GPX POI Editor
GPX POI Editor
3 Posts 2 Posters 87 Views 1 Watching
  • BertM
    wrote last edited by
    This weekend the first storm passed, and my back is telling me I am getting old, so it was time to do some things indoors:
    I have build me a POI converter in Google sheets to import data like KML en GPX and edit it.
    Problem is that is Google based, so not very flexible.(and it is Google...)
    As I wanted to learn more about Java Script, I ported a small part of my code to Javascript with the help of my new friend AI.
    This little tool is born because the POI interface of MRA is not the most flexible and sometimes you do not need a route and a track is all you want or have. I never liked Basecamp, so that is why I use MRA now to store my data
    I have different Garmins I use for cycling and walking and how cool would it be to have correct symbols after you made the route in MRA instead of the blue flags?
    With this little tool you can load your GPX file into a leaflet map and do the following:
    • Add symbols to your POI;
    • Add Notes to your POI
    • Move the POI, or add/delete one.
    • Geocode (get the address) with Openstreetmap Nominatum.
    • Merge tracks/POI files
    • Export it to an GPX file.
    • use different maps
    • Store your data in the browser cache.
    The tool is not storing your data on the internet, everything is handled inside the browser, also no API keys or other restrictions are used.
    I have uploaded the program into Github under the MIT license, so you are free to download and use it as you like. The program works with 3 files and can also be used on the computer ( you need internet for the Leaflet maps).
    If you do not want to download it, I have made a Github site, so you can use it from there:
    It can be that there are some Dutch words somewhere, so let me know if you find some.
    In the future I will also want to implement KML import, now it only works with GPX (1.1) files.
    Files on Github
    link to program on site
    • BertM
      some screenshots:
      loaded track
      Loaded GPX file
      POI without address data
      with address from openstreetmap
      POI with data
      imported in Garmin with symbols
      notes in Garmin POI
      • RainerT
        RainerT
        RainerT
        That is much more than a little program.
        Don't understand it completely at the moment.
        But anything that’s any good comes with a learning curve.
        Well done!
        RT
        RainerT
        RainerT
        • F014 WP Numbering illogical
        • Map colours and side roads
        • GPX POI Editor
          RainerT
          RainerT
        • F013 Facilities/POIs – A search function covering the entire map is unfortunately missing here.
        • Route MRA importeren in Google Maps
        • OSM Routing with MRA
        • F016 Colors only change after leaving the planning
