  2. Export assistance
  3. [Export] Garmin
  4. GPX1.2 & Garmin Tread
10 Posts 5 Posters 338 Views 1 Watching
  • Carl Lee Offline
    Carl Lee Offline
    Carl Lee
    wrote last edited by Carl Lee
    The latest Tread update 3.01.27 for iOS now does not calculate GPX1.2 again. The previous version did.
    Has anyone else noticed this and discovered a workaround? I have logged a ticket both through Tread mapping issues and Garmin customer support. To say I am disappointed is an understatement.
    I realise this is probably more of a Garmin issue, but it involves an MRA specific file.
    Thank you.
    • Carl Lee Carl Lee
      Thank you.
      John S Parry Online
      John S Parry Online
      Thank you.
      The only file transfer that works 100% of the time is manually copying the GPX file to your Garmin device. Tread has and always will be a potential problem. It's not what you want to hear, but the reality of the situation.
      • Carl Lee Offline
        Carl Lee Offline
        Carl Lee
        @john-s-parry yes, you’re right and I do copy files on to my SD card. 1.2 files still work that way without being corrupted by Tread. I’ve checked and even though what syncs to Tread looks wrong, the route in the XT2 calculates and remains true.
        It’s another string to the bow that has snapped. Again!
        • MTC-Zeilberg Offline
          MTC-Zeilberg
          Works fine here, no problems
          • Carl Lee Offline
            Carl Lee Offline
            Carl Lee
            @mtc-zeilberg are GPX1.2 files still being calculated by Tread for you? If so, are both your apps fully up to date?
            I've logged a ticket here and with Garmin who made me jump through several hoops before they would investigate.
            Stevedo 6 0 1 Reply Last reply
            • Danny 1d Online
              Danny 1d Online
              Danny 1d
              Hier hetzelfde probleem 3 weken terug werkte plots alles perfect GPX1.2 openen in Tread zonder dat deze de route veranderde overzetten naar de XT2 route openen en rijden ook inclusief harde punten. Nu na update zowel XT2 en Tread app werkt het niet meer de route (GPX1.2) veranderd nog steeds niet in de Tread app maar de XT2 kan het bestand niet meer berekenen en start bij berekening telkens terug op.
              • Carl Lee Carl Lee
                Stevedo 6 0 Online
                Stevedo 6 0 Online
                Stevedo 6 0
                wrote last edited by Stevedo 6 0
                I'd be extremely surprised if you get any help from Garmin in this instance. The reason is that GPX1.2 format is not an industry standard and, as far as I'm aware, proprietary to MRA who created it around 2019 to better work with Garmin devices.
                For reference, GPX1.1 is an industry standard created about 20 years ago.
                • Carl Lee Offline
                  Carl Lee Offline
                  Carl Lee
                  @danny-1d if I’ve understood you correctly, it is the other way round for me. All was working perfectly but now Tread will not calculate a GPX1.2 route. If I put the route onto the Zumo SD card, it works perfectly and is not recalculated by Tread.
                  The latest Tread update seems to be the problem. I am in contact with Garmin who are working on my ticket. Nothing back from MRA yet other than an acknowledgment.
                  • Carl Lee Offline
                    Carl Lee Offline
                    Carl Lee
                    @stevedo-6-0 I can hope and without asking, I we might not know. It’s not a showstopper but would be nice to get back.
                    I’m aware of the history of GPX1.2 and the standards so can maybe expect to be fobbed off but you never know.
                    • Carl Lee Carl Lee
                      Stevedo 6 0 Online
                      Stevedo 6 0 Online
                      Stevedo 6 0
                      Agree, no harm in asking 👍
                      Stevedo 6 0
                      Stevedo 6 0
                      Carl Lee
                      Carl Lee
                      Danny 1d
                      Danny 1d
                      MTC-Zeilberg
                      MTC-Zeilberg
                      • Rondrit maken lukt niet
                        Rob Vonk
                        Rob Vonk
                      • GPX1.2 & Garmin Tread
                        Stevedo 6 0
                        Stevedo 6 0
                      • Omweg door afgesloten weg
                        Thomas Neumeyer
                        Thomas Neumeyer
                        1.1k
                      • Missing option to avoid "unplaned" closed road
                      • Update 5.2.2 - Quick fix
                      • High Contrast Maps
                        1.4k
