Roundabout Symbol and Exit Number
In general the white arrow on a blue background appears to work well in bright sunlight.
However I have found two issues with roundabout symbol:- The exit number (for me on a 6inch phone) is too small to be easily seen, can this be made larger?
- The physical representation of some of the roundabout road positions is often incorrect. Example, the symbol showed exit 1 with the diagram showing the road exiting to the right when in reality exit 1 was just to the left of straight ahead, Is this a bug? I don't know where the system gets this data from?
@Angelo-Greco will work on topic 1 soon. Regarding 2, if it’s incorrect, the data we receive is wrong. It will be correct most of the time.
@Corjan-Meijerink Thanks!
Hi Corjan.
Riding in the rare UK sunshine this weekend and had the same thought as Angelo. It would be good to have a bigger number for the exit. While I do not need glasses for riding, on the 5.5" screen (Android Auto/Innovv) the exit number is impossible to see. I was going to come here to suggest about either a) having a setting to make it larger, b) change the format to O and number (O2 for second exit), or c) to have a second option for a big number to the right of the existing graphic.Did Angelo's issue get worked on in 2023 (and even with development is still going to cause issues)?
Hi @corjan-meijerink I hadn't seen this thread, and I actually made a similar proposal yesterday...
https://forum.myrouteapp.com/topic/11002/roundabout-exit-indicator-size-in-cp-aa
Regards!!
Hi,
Yes, roundabout exit number could be a bit larger, to be read on fast view on CP/AA
Regards -
Not only the roundabout exit number; maybe all the numbers can be a little bit bigger. I've heard more complaints about it in relation with smaller screens!
I myself do not have any problem for I have multi focus glasses and a larger (7")screen! -
@corjan-meijerink This is the view from the driving position on an 11" screen. The exits at roundabouts aren't very clear. Imagine trying to see them on a 5" or 6" screen on a motorcycle. It's a nightmare trying to read the numbers.
Òscar referenced this topic
