  4. Avoid roadblocks - how does it work?
4 Posts 2 Posters 72 Views 2 Watching
  • Jörgen
    Hi,
    I am trying to understand how this new feature works or how to enable something.
    For me it looks like (in the moment) that only "Select distance" is working.
    I should mention, though, that I'm only trying it here at home right now, so the conditions might not be right.
    If I use "Select distance" the next upcoming kilometers will be newly calculated.
    If I use "Select waypoint" or manual I get an error message and there is now new route.
    But I am not sure how to use it correctly.
    What is the correct way for select WP and/or manually?
    • Jörgen
      Morning,
      I played around a bit more with the new feature and found the following:
      Here the test route: https://www.myrouteapp.com/de/social/route/13652390?mode=share
      I started the route and the navigation, after the first announcement, I open the menu and select “Roadblocks.”
      Then select Waypoint
      From the WP list, select WP2 - ok works from start point (my current position)
      WP3 - ok works
      WP4 - ok works
      WP5 - Not ok error
      Next - Select distance
      5 km - ok
      20 km - ok
      25 km - ok
      30 km - Not ok error
      Next - Manually
      Start WP3 - End WP4 - ok
      Start WP4 - End WP5 - ok
      Start WP5 - End WP6 - ok
      Start WP5 - End WP7 - Not ok, error
      Start WP5 - End WP8 - Not ok, error
      The error comes because (may be too far or too many WPs)
        I can confirm there is a maximum implemented for how long a detour can be. I don't know how much, but based on your findings it looks to be 30 km. But I really don't know. I can imagine that is too short, especially in mountainesque areas.
        • Jörgen
          I did some further play.
          Manually
          Start WP6 - End WP7 - ok
          Start WP7 - End WP8 - ok
          Start WP8 - End WP9 - ok
          Start WP9 - End WP10 - ok
          Start WP9 - End WP11 - Not ok, error
          It seems that the distance from the current location doesn't matter—only the length of the detour.
          The detour must therefore be longer than 30 km.
            rpluckengmail.com
            rpluckengmail.com
            20
            34
            239
          • Kaart niet zichtbaar
            Nico Beerepoot
            Nico Beerepoot
            160
          • Google maps
            Stanisław
            Stanisław
            157
          • RouteXpert display on the map
            Corrado Miniati 0
            Corrado Miniati 0
            Emanuele 5
            Emanuele 5
            15
            30
            2.1k
          • Comparison route remains on map
          • Disabling Waypoints?
            Mike West
            Mike West
            Tim Verhaaf
            Tim Verhaaf
