  4. MRA 5.1.0 (462) Turn the card to stop and continue driving after a break
5 Posts 3 Posters 73 Views 1 Watching
  • Hubert Thoring
    Hello dear MRA team,
    Turning the map without clearly recording the direction of travel after a break is very disturbing, I think I have read that this should be improved in this version.
    After a break and then to continue the journey I start the MRA and the direction of travel or the map is then always / almost always misaligned .., only after about 100m the app catches and then also knows how to display the direction correctly.
    The problem apparently also has other apps, there is a solution, especially in unknown places this likes to lead to the wrong direction and then turn because it should go exactly in the other direction.
    VG 👋
    • Lluis Arasanz
      @hubert-thoring
      I noted this only occurs on Android.
      I tested 5.1.0 on iphone and map does not rotate.
      Waiting to Android version to test on it
      • BMW F750GS
        VG 👋
        You misread. It is already mitigated in the HERE SDK, but the new HERE sdk version is not implemented in the MRA app yet because of another bug in the HERE sdk that needs to get solved first.
        • Lluis Arasanz
          @con-hennekens yes, It could be Here SDK, but this only happens with Android.
          IOS is working with NO rotating map when stopped.
          I don't know if SDK is different on IOS and Android, but really is very annoying to be focused on next turn or indication because map can rotate if I stop on road.
          Hope it will be solved in next version.
          • BMW F750GS
          • Lluis Arasanz Lluis Arasanz
            Since Corjan already promised that, I have full confidence 😉
            Exactly which version remains to be seen though.
            • Strange translation
            • Crazy routing
            • Foutmelding In MRA Next
            • Kort voorstellen
            • My Routeapp Stays questions
