  4. MRA 5.0 - 424 In +MRA planning - no saving possible with offline?
6 Posts 3 Posters 69 Views 3 Watching
  • Hubert Thoring
    Good morning dear MRA team,
    It's almost done, the best update is ready.
    Offline test: Create route..?!
    I just happened to notice that you can probably not save a newly created route that you have created in the "MRA route planner", which, however, cannot be saved in this test without a network, i.e. in offline operation.
    • There is no way to leave this with save only if you discard the route.
    With an already existing route I can change it and then save it with the note that it will be synchronized later since offline.
      I don't believe this was ever possible in previous versions. To save means to add it to your library, which is online. You can however start navigating it from the menu. Maybe it could be placed in an upload queue, like tracklogs that cannot be uploaded.
      • Hubert Thoring
        @Con-Hennekens :
        It was possible offline in the old version, and I just tested it.
        It still works perfectly in the old 4.4.x version…
        So it should also work flawlessly in V5.0-424.
        This message appears when saving offline (see image), even when planning a completely new route with +MRA route planning in V4.4.x and saving it without network access on the phone, that works fine.
        • Hubert Thoring
          @Corjan-Meijerink , @Con-Hennekens
          So in short:
          Creating an MRA route in the app works offline, but then saving is not possible with the V5.0-424, that's exactly what should work for offline. In the old version 4.4.x it was perfectly solved.
          VG 👋
            So in short:
            VG 👋
            @Hubert-Thoring said in MRA 5.0 - 424 In +MRA planning - no saving possible with offline?:
            So in short:
            Please keep focussing on the short summaries 😉
              Fixed in the upcoming update
                Marcel Versluis
                Marcel Versluis
                Parantapa
                Parantapa
                TomOnTour
                TomOnTour
              • Android Auto TFT
              • Route punt overslaan
              • Notche
                Adriaan Vonk
                Adriaan Vonk
