  4. Avoid Highways when rout is loaded
11 Posts 4 Posters 80 Views 3 Watching
  • Jörgenundefined Online
    The following use case:
    I load a route and click on “Navigate.” The route starts. At that moment, I realize that I forgot to click on “Avoid highways.”
    Since I cannot change this during navigation, I have to cancel the navigation.
    I stop the route and am then asked, “Continue navigation?”
    If I click on “Navigate” again, I am back on the route as before, so I cannot change anything.
    To avoid highways, I have to click on “No” at this point and reselect the route from the menu. Only then can I go to the point where I can deselect ‘Highways’ under “Avoidances.”
    In this case, it would be much more user-friendly if you could either select “Avoid highways” while the route is still loading (as was previously possible with TomTom Rider), or if, after cancelling and continuing navigation, you had the option to select avoidance options such as highways.
      Hey Jürgen, das hatte ich auch, Corjan hat dann nett erklärt das bei mir die Navigation auf „Navigieren Sie Routen als Track“ steht, habe es auf Aus gestellt dann stehen die Routenoptionen auch wieder zur Verfügung
      Hey Jürgen, I had that too, Corjan then nicely explained that the navigation is on "Navigate routes as track", I set it to off then the route options are also available again
      https://forum.myrouteapp.com/post/70541
      Antwort von Corjan
      https://forum.myrouteapp.com/post/70542
        Hi Hubert, you misunderstand my suggestion. Read it again. I am missing nothing.
        Bytheway, my name is Jörgen.
          Nachtrag: Gehe nach dem Verlassen der Route und dem bestätigten Nein, einfach auf letzte Route oben rechts im Menü, dann nach dem laden auf Navigieren dann stehen dir die Optionen zur Verfügung bevor Du erneut Start drückst.
          Addendum: After leaving the route and the confirmed no, simply go to last route at the top right in the menu, then after loading on Navigate then the options are available to you before you press start again.
            Thank you, the way to this is clear for me. But not what I like to have.
              Con Hennekensundefined Online
              @Hubert-Thoring said in Avoid Highways when rout is loaded:
              Corjans Antwort bezog sich auf einen Unterschied zwischen Route und Track, was hier überhaupt nicht zur Debatte steht.
              Auch das ist keine Lösung, denn „letzte Route” steht für die zuletzt geänderte Route (also im Planer), nicht für die zuletzt navigierte Route.
              • Jörgenundefined Jörgen
                @Jörgen, changing road preferences would make sense for A2B routes (direct to destination indeed.
                  How about the part of the route to the starting point?
                    @M.-Schrijver, that can be addressed as an A2B route, can it not?
                      I used to use these route preferences a lot with TomTom. It was very practical. For example, when planning a route, you would set a waypoint near the highway and the next waypoint off the highway where you wanted to exit.
                      The route setting was always “fastest.” This meant you were automatically guided onto the highway.
                      If you changed your mind at short notice and didn't want to take the highway, all you had to do was click on “avoid highways.”
                      As I said, this was very practical when on the road and is currently not possible with MRA that way.
                        @Con-Hennekens said in Avoid Highways when rout is loaded:
                        Yes. It is a A2B route but it is a part of the planned route. Not a separate route. At least how i use it.
                        • Tussenstop/routepunt toevoegen tijdens navigeren
                          284
                          Daniel 7undefined
                          Daniel 7
                        • 'Toon route' optie eenvoudiger beschikbaar maken
                          Bart De Medtsundefined
                        • Gas Stations not displaying
                        • Routepunt met adres invoegen
                          Travellexxieundefined
                          5.3k
                        • Statement on map spinning
                        • Flexibility of Speed Alerts
                          Axel Härtlundefined
                          Axel Härtl
