  4. Settings and BarButtons
1 Posts 1 Posters 33 Views 2 Watching
  • Jörgen
    I don't know if it has to do with the update or the new design.
    When you go to the setup menu using the BarButton, you could adjust a number of settings without touching the screen.
    In the map settings, you can now only get as far as the first slide menu. See picture.
    This is because the four-way buttons (up, down, right, left) no longer work from this point onwards.
    Instead of right and left for the scroll button, the up and down buttons also work for moving left and right the button.
    You can then neither go to the next menu item nor go back.
    You are basically stuck here and cannot continue. It looks like up/down Code from BarButtons use the same code for left/right of the slide bar, or vice versa.
    It doesn't work with the menu return button, either.
      Erdna
      Erdna
    • Minimap
      LE DIZES Freddy
      LE DIZES Freddy
    • Bollard trouble
    • Map movement
