  4. MRA 5.0 Folgemodus HERE (Alt - OSM) // MRA 5.0 follow mode HERE (Alt - OSM)
5 Posts 3 Posters 94 Views 2 Watching
  • Hubert Thoring
    Hey ihr,
    wie geht denn der Folge Modus jetzt ?
    Gibt es den noch ?
    Hey guys,
    How does the follow mode work now?
    Is it still available?
    • Hubert Thoring
      The test just shows that the "follow mode" probably doesn't exist anymore ..
      Map is oriented to the north and apparently cannot be adjusted in the direction of travel ...
      What reason was there not to offer this anymore?
      Old view was horizontal and vertical okay but only online good.
      New view is no longer what makes a good sequence mode.
      Old view:
      New view horizontal, unfortunately the new menu disturbs
      New vertical view, not like that anymore?
      North orientation is fixed?
      • Hubert Thoring
        Nachtrag:
        In dem Folge Modus der keiner mehr ist kann man auch nicht mehr Zoomen es gibt keine Tasten +/- mehr ?
        • Auch mit der BT Tastatur geht das nicht.
        Also ist der Folge Modus wohl nicht mehr vorhanden oder ?
        Addendum:
        In the following mode that is no longer one, you can no longer zoom, there are no buttons +/- anymore?
        • Even with the BT keyboard this does not work.
        So the sequence mode is probably no longer available or?
        • Hubert Thoring Hubert Thoring referenced this topic on
          The map still zooms by gestures. There never was any intention for a "following mode". That's probably just what you used the base map for. It would be good though when the menu could be swiped down a bit, to enlarge the view on the map. But I am confident that changes have been done preliminary to the much requested "free-ride" mode. The current beta is no end-station in development 😉
            Will be in the next beta version
              Erdna
              Erdna
            • Minimap
              LE DIZES Freddy
              LE DIZES Freddy
            • Bollard trouble
            • Map movement
