  4. Anyone problems with iOS 18.5?
11 Posts 8 Posters 139 Views 3 Watching
  • Jörgenundefined Offline
    Hi,
    in my Facebook group, someone is having problems with MRA and the new iOS 18.5.
    I do not want to update my phone yet.
    I don't know if I'm the only one with this problem, but since the iPhone update to 18.5, the MyRoute app regularly ‘freezes’ during navigation.
    I travelled to the Hunsrück in my motorhome this weekend. After a while, the app was really jittery, i.e. the 4 buttons at the bottom right were flashing, the next departure, which is always shown as scrolling text, stopped or jerked.
    I closed the app and restarted it, which sometimes lasted 5 or even 20 minutes, but there was no improvement in sight.
    iPhone 12 pro (iOS 18.7.1)
    Oukitel RT3 pro (Andr. 14)
    More information about Workshops here
      Hey Jörgen,
      ich habe meine Geräte alle auf iOS 18.5 geladen, das Upgrade macht so keine Probleme.
      • MRA allgemein okay
      • MRA Navigation ohne Probleme
      • Navi App über 200km gestern betrieben
      • Remotek One Bedienung ohne Probleme
      1. Handy iPhone Xr Navi ohne Sim okay
      2. Handy iPhone Xr im Tankrucksack mit Sim im Hotspot für Nr. 1 Handy okay
      VG 👋
      iPad 9. Gen iOS 26.2 / iPhone 16e iOS 26.2 / iPhone Xr iOS 18.7.3 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
      • Ad Koppenolundefined Offline
        Ad Koppenol
        After updating iOS 18.5 on iPhone 13 Pro:
        May 16, 2025: The app on my iPhone started blinking and freezing after some time (50 minutes). The ability to turn off the app (3 dots) was also gone. After restarting the iPhone, the app worked properly again. After this, I have not needed the app to this day so I can't tell more about it.
          Hi, I made the update tonight and have no problems. App works fine.
          Thank you.
          • Jürgen Wallochaundefined Offline
            Jürgen Wallocha
            Am vergangenen Donnerstag hatte ich ebenfalls Probleme (im Wohnmobil-Modus) nach dem Update auf 18.5 (iPhone 15 ProMax). Die App ist mitten auf der AB (in Bonn erstmalig) eingefroren, oder begann an den 4 Schaltflächen unten rechts hektisch zu blinken. Hat sich auch bis zur Zielankunft nicht mehr gebessert.
            Zwischenzeitlich kam ein Update via TestFlight, aber am eigentlichen Problem hat sich nichts geändert.
            Auf der Heimfahrt am Sonntag waren die ersten 50km unauffällig, jedoch danach ging es wieder los mit den Aussetzern.
            Werde erstmal neu starten und die App komplett deinstallieren und wieder neu aufspielen.
            Nächster Test ab Donnerstag auf dem Motorrad Richtung Vogesen.
            Bleiben die Probleme, als Reserve Calimoto geladen als Testversion für 2 Wochen.
            Fahre seit Jahren mit MyRoute-App durch halb Europa, aber so schlimm war es noch nie, schade....
            • Jürgen Wallochaundefined Jürgen Wallocha
              Nick Carthewundefined Online
              @Jürgen-Wallocha Please use the language that the topic was started with. Thanks.
                Jürgen Wallocha
                Last Thursday I also had problems (in motorhome mode) after the update to 18.5 (iPhone 15 ProMax). The app is frozen in the middle of the AB (in Bonn for the first time), or started flashing frantically at the 4 buttons at the bottom right. Has not improved even until the arrival of the destination.
                In the meantime, an update came via TestFlight, but nothing has changed on the actual problem.
                On the way home on Sunday, the first 50km were unremarkable, but after that it started again with the dropouts.
                Will first restart and completely uninstall the app and reinstall it again.
                Next test from Thursday on the motorcycle towards Vosges.
                Remain the problems, as reserve Calimoto loaded as a trial version for 2 weeks.
                I've been driving through half of Europe with the MyRoute app for years, but it's never been so bad, too bad....
                • UltraStarundefined Offline
                  UltraStar
                  iPhone 12P, iOS: 18.5; MyRouteApp: 4.3.9 - 395
                  I have had several problems with the navigation.
                  First, the icons on the screen are jumping left and right. I have noticed that at the gas station first time, the gas station icon was jumping left to right. I have notice that several more times with different icons while driving/riding.
                  Second, I have tried to get to the settings during navigation. When I pressed ellipsis button, the menu showed up, but it was jumping up and down. I could not scroll, and could not select any items on the menu. At that time, I have tried to end navigation, but I was unable to do that. I have shot down the application, and after I restarted, I have been asked if I want to continue the navigation. All worked fine from now on. (I did not try to do anything funky from then on.)
                  Third, the buttons on the right bottom start jumping up and down during the navigation. I can see the part of the black background of the button location square. The buttons do not respond to any entry while in the jumping mode.
                  Fourth, the map did not showed up several times, when I tried to navigate from A to B. The background was black, the start and end flags were visible. One time, while navigating, the map went black. The navigation continued, but on the black background. Restart of app fixed the problem.
                  Fifth, one time-when I got to the settings-the menu covered part of the map, and I could not get it out; the screen was frozen. Restart of the app fixed the problem.
                  Sixth, once, while navigating, the blue line disappeared, the location icon was facing to the right, and navigation continued.
                  I got some videos of the blinking icons and menus, but I do not remember how to upload them.
                  • Jörgenundefined Jörgen
                    Hi,
                    Rob Verhoeffundefined Online
                    @Jörgen No problems at all.
                    • paul69undefined Offline
                      hi @Jörgen
                      recently rode multi day trip, iphone 13 pro ios 18.5, no issues to report although was connected to carpuride 702b.
                      K1600 GTL
                      Oukitel RT3
                      iPhone 13 Pro, carpuride 702b
                        Ok, thanks.
                        I think that was a one-time thing.
                        paul69undefined
                        UltraStarundefined
                        UltraStar
                        Jürgen Wallocha
                        Ad Koppenol
                        • New beta! 5.0.2 (438) - free drive
                          Theo Lammertsundefined
                          Theo Lammerts
                          102
                        • Anyone with CPMC B6?
                          CD130undefined
                        • Maybe last tour this year
                        • Sound issues in AA with MRA Navigation
                          1.3k
                        • MRA 5.0 - 420 Folge Modus so nicht nutzbar // Follow mode so not usable
                        • CarPlay and app not showing route
                          Aiello antoninoundefined
                        • scenic route inkorten
                          ReneKundefined
                          ReneK
