Strange blue line behavior
Was out for afull days ride today. Myrouteapp worked great, both offline and online. Battery was held at 100% by my Quadlock wireless charger, direct wired.
I did notice that the blue line behaved a little strange. It was always ahead of my position Marker. After we stopped for a break and i restarted the route, it corrected itself and acted normally. Screen stacking was smooth for both cases and navigation was not affected.The following shows the blue track line ahead of the position marker.
The following shows normal behavior.
@RetiredWingMan Does that really bother you?
@Jörgen It irritates me as well. It’s abnormal behavior that shouldn’t happen.
@Rob-Verhoeff I completely agree with you
@Rob-Verhoeff, It would be nice if it could be perfected, but there are much bigger irritations to be solved first
@Jörgen I have something like that happening to me all the time. The route is displayed in a transparent blue line, and the dark blue line disappears for a second. The dark blue line slides slowly from the top to the current location marker, not necessarily all the way. The whole thing looks really cool. The problem I am having is that, the whole phenomenon catches my eye, and I have a tendency to focus on display not on the road, and that might be an issue.
@Con-Hennekens you miss the point. In of itself this is not a big deal but it may indicate a bigger problem or reporting it may help to solve other related issues. Inane case the behaviour is not normal and should be reported.
@UltraStar ok I understand
@RetiredWingMan I am sure it is known already -
Thanks for reporting.
It’s definitely something that needs tweaking
