  2. New Users' corner
  3. new user with qestion
3 Posts 2 Posters 919 Views 2 Watching
  • Eddy van de Bunt 0undefined Offline
    Eddy van de Bunt 0
    hi there i am also a new user name: Eddy from the Netherlands
    i did use base camp and nowe my route
    question 1 i can continue a route at a ferry trick in the manual dos not work
    question 2 when you make a route far away the program generates a route to the staring point
    thanks Eddy
    • Eddy van de Bunt 0undefined Eddy van de Bunt 0
      thanks Eddy
      Rob Verhoeffundefined Offline
      @Eddy-van-de-Bunt-0 said in new user with qestion:
      Set the travel mode to 'Auto' and select "Shortest route" under Route Optimization from the Toolkit menu. You will then navigate across the ferries without any issues.
      There is an option in the app's menu to start navigation only from the starting point.
      Eddy van de Bunt 0undefined 1 Reply Last reply
        Eddy van de Bunt 0
        @Rob-Verhoeff dank Rob probleem opgelost
        Eddy van de Bunt 0
          Peter Zehentreiterundefined
          2.7k
          Axel Härtlundefined
          Axel Härtl
          627
          Aiello antoninoundefined
          27
          46
          2.9k
        • Need to adjust Time based on speed limits.
          492
          Jan Weerheimundefined
          Jan Weerheim
        • Doe ik iets verkeerd of...
          Michel 71 0undefined
          Michel 71 0
        • Route wijkt af van de geplande route
