  4. continue navigation after crash not possible
4 Posts 3 Posters 42 Views 1 Watching
  • Lisi Mayr Offline
    Lisi Mayr Offline
    Lisi Mayr
    After a crash, navigation cannot simply be continued. I have to end with 'no' and reopen the route and then select the appropriate route point so that I don't have to manually skip all of them.
    When continuing, you just get a gray screen.
    I'm using Android Version 4.0.3 - 209
    Rob Verhoeff Con Hennekens 2 Replies Last reply
    • Lisi Mayr Lisi Mayr
      Rob Verhoeff Offline
      @Lisi-Mayr it’s a wellknown issue. Repairs are underway. Hopefully the upcomming update will solve the problem.
      Lisi Mayr 1 Reply Last reply
        Lisi Mayr Offline
        Lisi Mayr Offline
        Lisi Mayr
        @Rob-Verhoeff thank you
          @Lisi-Mayr said in continue navigation after crash not possible:
          You know you don't need to skip them one-by-one, don't you?
          Just start navigating and pinch/zoom to the waypoint of choice, long press the waypoint from where you want to resume
          Lisi Mayr
          Lisi Mayr
          • It was not possible to find a correct route to Wheels Through Time
            242
          • Is there a way to put a Home button in the program
          • MRA 5.2.2 (489) Route time is calculated incorrectly /// Strecken Zeit wird falsch berechnet
          • Is there a way to re-order the routes in your routes folder?
          • Route doesn’t recalculate to my destination
            Bruno 7
            Bruno 7
            627
          • MRA In the BMW - Cradel vertically and horizontally /// MRA im BMW - Cradel senkrecht und waagerecht nutzen
