  4. Navigation to POI not possible offline
13 Posts 5 Posters 128 Views 1 Watching
  • Calibos
    Calibos
    Calibos
    impossible de faire fonctionner la navigation hors ligne vers un POI.
    1-Phone in airplane mode
    2-select POI ok
    3-Navigate...impossible
    does this work for anyone? I couldn't get it to work
    Stefan Hummelink ATLast 2 Replies Last reply
    • Calibos Calibos
      2-select POI ok
      @Calibos Silly question: but do you have the offline map for your region installed?
      Calibos 1 Reply Last reply
        Calibos
        Calibos
        Calibos
        @StefanHummelink
        yes all the cards are up to date and installed for europe
        • Arno 0
          Arno 0
          Arno 0
          Maybe you should also activate the "ofline navigation" switch in the Functional - Navigation settings?
          • Arno 0 Arno 0
            Calibos
            Calibos
            Calibos
            @Arno-0 I tried with and without it's the same thing
            Arno 0 1 Reply Last reply
            • Calibos
              Calibos
              Calibos
              does this work for you?
              RetiredWingMan Arno 0 2 Replies Last reply
              • Calibos Calibos
                Arno 0
                Arno 0
                Arno 0
                @Calibos I have no problems and it works on both my Android and iOS smartphones.
                • Calibos Calibos
                  @Calibos works for me, both offline and online with no Internet. Android and next v 4.0.2 202
                  • Calibos Calibos
                    Arno 0
                    Arno 0
                    Arno 0
                    @Calibos By the way, do you use the latest 4.0.2 version which is build 202?
                    • Calibos
                      Calibos
                      Calibos
                      yes last version too, I have to retest tomorrow
                      • Calibos Calibos
                        2-select POI ok
                        ATLast
                        ATLast
                        ATLast
                        @Calibos Airplane mode may also disable the Gps, thus no way to route somewhere.
                        Try turning off wifi and datas only, and try again
                        • ATLast ATLast
                          @ATLast airplane mode does not disable location services. I was driving a route today. My phone overheated and shut down all apps. After it cooled down and I tried to restart the route it failed. I eventually had to enable offline to get the route planned for navigation. Yesterday I was testing on my tablet and thought it worked with offline enabled or not. Today I confirmed that is not correct. For a downloaded route and no Internet offline must be enabled. However, it appears that navigating o a favourite does not need to be offline.
                          • Calibos
                            Calibos
                            Calibos
                            Good that's it I found the reason for my problem. I installed the application on my smartphone and on my tablet for motorcycle navigation but I only downloaded the offline maps for the tablet which it has an SD card to hold the maps.
                            so I tested this morning with the tablet and there miracle it works too wel!!😳
                            Great feature.
                            Kudos to the developers👍
                            ATLast
                            ATLast
                            Arno 0
                            Arno 0
                            Calibos
                            Calibos
                            • Here Terrain maps style
                              100
                            • Migration of my data
                              Solo1138
                              Solo1138
                              132
                            • MRA AI Routeplanner credits
                              109
                            • Map viewing options
                              Edwin_M
                              Edwin_M
                            • Hello from England.
                            • AI Weather forecasts
