  4. Prima prova vera, salta waypoint, elimina waypoint
7 Posts 3 Posters 119 Views
  • Michele Skipper
    Michele Skipper
    Michele Skipper
    Iphone 14 pro iOS 16.5
    Oggi ho provato per la prima volta in un viaggio in moto. Ho utilizzato un gpx relativamente semplice con soli tre waypoint, ma รจ stato sufficiente per capire che ci sono cose che ancora non funzionano come dovrebbe, anche se penso che ci stanno lavorando.
    faccio tre esempi:
    • salto multiplo di waypoint
    • partenza o ripartanza da uno specifico waypoint
    • autozoom
    • Michele Skipper Michele Skipper
      faccio tre esempi:
      • autozoom
      @Michele Could you please indicate the version of the app you are using?
      Regarding the first issue, I'm not completely sure what you mean.
      The rest is already possible ๐Ÿ™‚
      Michele Skipper 2 Replies Last reply
        Michele Skipper
        Michele Skipper
        Michele Skipper
        @Corjan-Meijerink versione 3.2.15 (173)
          Michele Skipper
          Michele Skipper
          Michele Skipper
          @Corjan-Meijerink said in Prima prova vera, salta waypoint, elimina waypoint:
          Allora non ho capito com si fa, c'รจ un tutorial?
            @Michele, Instead of forcing the people who want to help you to use Google Translate, maybe you can try that yourself?
            • multiple waypoint jump
            Simply long press the waypoint you want to skip to. If you are referring to the automatic skipping, it will not skip multiple waypoints by design.
            • departure or restart from a specific waypoint
            Simply long press the waypoint you want to start from.
            • autozoom
            How it works has been mentioned in the release notes of todays update:
            https://forum.myrouteapp.com/topic/4381/new-beta-v3-2-16
            Michele Skipper 1 Reply Last reply
              • autozoom
              Michele Skipper
              Michele Skipper
              Michele Skipper
              @Con-Hennekens Many write in German, Dutch, French, some in Spanish and I can't write in Italian? Weird thing. In any case, I still don't understand if and how the autozoom is activated and I add that I can't find some basic information for me: for example the altitude, which is important information for those who do tourism. Thanks for the attention.
                @Michele, Thank you for turning to English. It will broaden the audience for your message.
                Altitude indeed is not in the parameter set. Some people (me included ๐Ÿ˜‰ ) have been asking for it. Hopefully some extra data fields will become available when development progresses.
                Michele Skipper
                Michele Skipper
                • Testroute segmenten
                • Bollard trouble
                • Hide warnings on the map
                • Minimap
                  LE DIZES Freddy
                  LE DIZES Freddy
                  Erdna
                  Erdna
