  4. Begoning of the route
10 Posts 6 Posters 103 Views 2 Watching
  • antonio castelloundefined Offline
    antonio castello
    When starting a route, it will be better to have as preset THE CLOSES POINT instead of THE BEGINNING OF THE ROUTE
    Lynchy67undefined 1 Reply Last reply
    • richtea999undefined Offline
      This post is deleted!
      • antonio castelloundefined antonio castello
        Lynchy67undefined Offline
        Lynchy67
        @antonio-castello
        That is already possible, but maybe not exactly as you'd expect it to be.
        You can join a route (and a Route-Track) at any point on your Route.
        So you drive to the "Closest Point" then open the route and "Long Press" the Waypoint you want to start at.
        So if it happens to be Waypoint 22 then Waypoints 1 to 21 are ignored.
          @Lynchy67 said in Begoning of the route:
          @antonio-castello
          No need to drive!
          • Open route
          • 'Navigate' (now all the waypoints are visible)
          • long press the waypoint you want to start from
          • route now alters to show the route to the revised starting point, and also the rest of the trip
          • 'Start'
          Edwin_Mundefined Lynchy67undefined 2 Replies Last reply
          • Dikke Wimundefined Offline
            Dikke Wim
            Or place the starting point NOT in front of your house but ±50m away from it, in the direction you want to drive the route! This way you don't have to skip the first waypoint 🙂
              @antonio-castello
              No need to drive!
              • Open route
              • 'Start'
              Edwin_Mundefined Offline
              Edwin_M
              @richtea999 this looks to me the closest to the desired way of working of topicstarter. Just tried it and that seems to work.
              Although I can also relate to topic starter that he wants that. That was also my first thought.
                @antonio-castello
                No need to drive!
                • Open route
                • 'Start'
                Lynchy67
                @richtea999
                If you look at the opening post he is interested in starting the route from the “closest point” to him rather than the start of the route.
                That’s how I interpreted it.
                richtea999undefined 1 Reply Last reply
                • Lynchy67undefined Lynchy67
                  @richtea999
                  @richtea999
                  Ah - got you! In other words MRA needs to calculate the nearest point on the route (not necessarily a waypoint), rather than the user manually examining the map. Understood. My mistake.
                  So it might be described as:
                  • I've got lost, but I'd like to try and reset with the least loss to my carefully planned route.
                  Lynchy67undefined Herko ter Horstundefined 2 Replies Last reply
                    @richtea999
                    Lynchy67
                    @richtea999
                    I can’t speak for @antonio-castello but have you never started a route in the middle of it instead of at the start?
                    Maybe the OP was a bit stretched for time so started the route mid way.
                    I do it all the time.
                    There is no mention by the OP of being lost?
                      @richtea999
                      @richtea999 I don't think getting lost is the primary use case here. As @Lynchy67 says, it may just be you don't want to go the added distance of going to the starting point. The route may be one you've picked up from elsewhere, which is why it doesn't have a completely suitable starting point. Or you may simply have to restart/reload the app (for whatever reason) somewhere along the way and you just want to pick up where you left off.
                      richtea999undefined
                      Edwin_Mundefined
                      Edwin_M
                      Dikke Wimundefined
                      Dikke Wim
                      Lynchy67undefined
                      Lynchy67
                      antonio castello
                        Nomko Nomdenundefined
                        Nomko Nomden
                        279
                        398
                        Ronnie Mooreundefined
                        Ronnie Moore
