  4. Use of other Iphone for Navigation
10 Posts 6 Posters 156 Views 1 Watching
  • Gert Nivelle
    Gert Nivelle
    Gert Nivelle
    wrote on last edited by Gert Nivelle
    Hello, I've been added to the test Group recently. I have an Iphone 14 and did my registration with this Iphone. However, I want to use my previous phone for the Navigation (Iphone 12). Apparently the new app is not only linked to my account, but also to the Iphone 14. Is that correct? Can I get the test app also on that previous model (iPhone 12). W're planning a trip to Scotland beginning of July. When using another phone for navigation only, I can use my Iphone14 to take pictures or do a call during the stops. Thanks in advance for your feedback.
    Con Hennekens Rob Verhoeff 2 Replies Last reply
    • Gert Nivelle Gert Nivelle
      @Gert-Nivelle, do you by any change have a different apple ID on that second device? Your beta status is linked to your apple ID. It think they will help you when you open a support ticket for it.
        Yeah, in any case it’s best to contact support about these matters 🙂
        • Gert Nivelle
          Gert Nivelle
          Gert Nivelle
          Thanks for the feedback. No I do not have another Apple ID on the second Iphone.
          On the Iphone 14 I see an orange dot next to the MRA app. I suppose this indicates that it is the test version? On the iPhone 12 I don't have that.
            @Gert-Nivelle, Can't help you there. It is still the best idea to contact support.
            Gert Nivelle 1 Reply Last reply
              Gert Nivelle
              Gert Nivelle
              Gert Nivelle
              @Con-Hennekens Ok! thanks
              • richtea999
                It can be done - I have the MRA beta on both an iPhone and an iPad.
                Only three things to remember:
                1. use the same Apple ID (you've done that)
                2. install TestFlight on both devices and get the beta from there. Don't go to the AppStore
                3. Log into MRA (using your normal MRA account, which might be different to your Apple ID) on both devices if you want to see the same info on both
                • arcangelenruta
                  arcangelenruta
                  arcangelenruta
                  @Gert-Nivelle I have it installed on two iPhones (Xr and 12 Pro) and it works without any problem on both. In both I have the same Apple ID and in both I have TestFlight installed to be able to download the beta version of MRA.
                  Rafael Rodriguez
                  Honda GL1800BD Goldwing
                    @Gert-Nivelle works fine for me too. Installed on iPhone 13 en iPhone 5S (yep, I thought that was not possible 😁 ). Just installed to confirm that it's possible on multiple devices.
                    • Gert Nivelle
                      Gert Nivelle
                      Gert Nivelle
                      Thanks for the clear info.
                      arcangelenruta
                      arcangelenruta
                      Gert Nivelle
                      Gert Nivelle
                      • Strange translation
                        43
                        martin-phogel.de
                        martin-phogel.de
                        10.7k
                      • Undo/Redo tool is hidden
                      • Shared toggle switch
                      • Crazy routing
