  4. skip routepoint acknowledge button bigger please.
8 Posts 2 Posters 72 Views 1 Watching
  • Edwin_Mundefined Offline
    Edwin_M
    With gloves I am struggling to acknowledge the skip routepoint. If you tap beside it. It disappears and you need to do the procedure again.
    For me a bigger acknowledge button would be great. I therefor am also in doubt if it sometimes didn't work or that I simply missed the button
    • Edwin_Mundefined Edwin_M
      @Edwin_M you can click anywhere on the popup to acknowledge the action 🙂
      Edwin_Mundefined 1 Reply Last reply
        Edwin_M
        @Corjan-Meijerink my experience was only in the yellow will it be confirmed.
        (Or sometimes it didn't work properly)
          Edwin_M
          @Edwin_M maybe this setting could also have some effect. It was set on average.. just switched it to short. Maybe I should test again.
            @Edwin_M that could very well be cause I know for sure how it should work 😉
              Edwin_M
              @Corjan-Meijerink I can confirm that way of working. Just tested without gloves and it worked as you said 👍
                @Edwin_M great! 🙂
                  @Edwin_M great! 🙂
                  Edwin_M
                  @Corjan-Meijerink I also saw that the higher screen sensitivity was disabled for some reason. Maybe with the latest update as I normally had it set to on. 🤔. This could explain some issues I had today.
                  Edwin_Mundefined
                  Edwin_M
                  • v5.2 (473) Feedback
                    Lenny Oundefined
                    Lenny O
                    1.2k
                    nomkoundefined
                  • Permanent afgesloten wegen voor motorrijders
                    Leike Lodiersundefined
                    7.8k
