  4. shortcut to route on homescreen
13 Posts 9 Posters 170 Views 1 Watching
  • Tony_U
    Tony_U
    Tony_U
    Hi all,
    Thanks for this really great route planning tool. We have a small campervan and for planning our Ireland tour this year I came across MRA.
    Now, while using it so far, I have noticed that we often make stops on our tours where I completely close the MRA app in order not to leave it running in the restaurant or during other activities. Now, when I am back in the vehicle, I would like to continue with the navigation and possibly the tracking. To do this, however, I have to search for the route in the menu and reload everything.
    Is it therefore possible to have a link or a widget on the home screen where my desired route is stored directly and the app starts directly with the navigation and tracking? That way I can get in and continue with the push of a button.
    Best regards
    Tony
    Frappawotsit 1 Reply Last reply
    • Tony_U Tony_U
      Hi all,
      Best regards
      Tony
      Frappawotsit
      Frappawotsit
      Frappawotsit
      @Gertrud-Bürstner said in shortcut to route on homescreen:
      Best regards
      Tony
      If I understand your request properly, this function is already available from the Mobile app.... it's at the top, shown as "Last Route" which opens the last route you had open and you can choose the Navigation button from there.
      UltraStar 1 Reply Last reply
      • Frappawotsit Frappawotsit
        Best regards
        Tony
        UltraStar
        UltraStar
        UltraStar
        @Frappawotsit This is just a question: my understanding was that Last Route button will take you to the last route that was worked on using Webapp on the PC, not the last navigated route, no? It would be great if we had a button to return to the Last Navigated Route.
        Lynchy67 Frappawotsit 2 Replies Last reply
        • UltraStar UltraStar
          Lynchy67
          Lynchy67
          Lynchy67
          @UltraStar @Corjan-Meijerink
          As MRA are great at giving its end users choices, I
          suppose it makes sense to officially request that we also have the option to return to the last Navigated route as well.
          As we are talking about the Navigating in the mobile app I guess this would not be a priority but maybe something for after the release?
          • Dae 0
            Dae 0
            Dae 0
            This sort of ties in with a suggestion I made.
            We always put departure dates and times in routes, so it would be good to have the button (user configurable if desired) allow you to navigate the route that you should be on based on the current date/time. This would emulate the Garmin behaviour where the route that you “should be on” is at the top of the list of routes you want to select to navigate. The remaining routes are displayed in departure date order, most current at the top
            • richtea999
              I'm in favour of this - especially since the app could remember 1) the route wasn't completed, and 2) the route was used only xx minutes/hours ago, and therefore a good default would be to offer to resume the part-navigated route on the next opening of the app.
              • Rob Verhoeff
                Option: two yellow chekboxes instead of one
                left: last edited route
                right: last navigated route
                Couldn't find some ux-icons to go with the text. The flags are good for navigation?
                  Frappawotsit
                  Frappawotsit
                  Frappawotsit
                  @UltraStar My bad, you are indeed correct. Sorry for any confusion
                    Yes, we are thinking about this 🙂
                    Don’t want too much buttons or ambiguous behavior. Now it aligns perfectly with the same button on the website.
                    Dae 0 1 Reply Last reply
                    • Tony_U
                      Tony_U
                      Tony_U
                      I am pleased that my post has led to a small discussion and that there are other users with similar wishes.
                      I myself was thinking more of the possibility of selecting a route in the app and then making a shortcut on the homescreen. Similar to the playlists on Spotify.
                      But this is a function that can be further developed in the final version.
                      Currently, the loading of the route itself is still a bit slow for me, although I have it available offline.
                      • Tony_U Tony_U
                        You need to access the downloaded routes via the "hamburger menu", then then enter the profile (the button on the absolute top right), and choose "Downloads". If you load the routes like you usually do through the Routes option, it will still get downloaded on accessing. This behavior is likely to get changed in an update (I hope 😉 )
                          Dae 0
                          Dae 0
                          Dae 0
                          @Corjan-Meijerink said in shortcut to route on homescreen:
                          Unfortunately I’d say that the button is already ambiguous, given many people don’t know if it means last used, last edited etc.
                          I personally wouldn’t expect the same buttons if in different modalities, e.g. navigation or route planning. They’re two very different activities and therefore I’d expect the buttons/menus/options to be relevant to the current use case.
                          • Dae 0 Dae 0
                            @Dae-0, I agree. And I don't think that it will be a problem.
                            @Corjan-Meijerink Users of the navigation part of the app, find it very logical to use that button to start the latest driven route again. People who use different means of navigation, will not start any routes for navigation in the app, and the last edited route is openen by that same button (like it is now). When I access the planner to edit or create a new route (be it the mobile app planner or the online planner), I am perfectly fine with it when that route gets opened by that same button. So, I would say one button is enough, and needs to be redefined as "last edited OR driven route" (whichever comes last).
                            Dae 0
                            Dae 0
                            Frappawotsit
                            Frappawotsit
                            UltraStar
                            UltraStar
                            Tony_U
                            Tony_U
                            Lynchy67
                            Lynchy67
                            • Hello everyone
                            • Route changed?
                            • Hoe lang moet je abo hebbes voor toegang??
                              Rob Veerman
                              Rob Veerman
                            • Beurs aanbieding
                            • Wissel Here-TomTom
                              Reinhard Grossmann h 0
                              417
