  4. Offline maps
Offline maps
24 Posts 8 Posters 442 Views 1 Watching
    I get this error also quite often. In the meantime I have downloaded Belgium and Luxemburg, but downloading Germany and the Netherlands seems impossible, there is just ZERO progression.
    I think I had some maps downloaded prior to the update. Is it possible I need to delete those old downloads because they are not recognized, but that they are conflicting with the new downloads?
      @Con-Hennekens that should not be required but we are aware the offline maps state management isn’t at the level we need it to be πŸ™‚
        @Corjan-Meijerink, I took the cow by the horns (reference to https://www.facebook.com/MakeThatTheCatWise/) and deleted cache and data for the app. Then I went back in and tried downloading the Dutch map. It doesn't download (keeps circling, no progression, also not after a long time). Then I took my other phone. There were already some maps downloaded prior to the update and they were shown as present. I tried downloading another map that wasn't already downloaded. It failed, as failed the download of the Dutch map after deleting it (by pressing the X). I stopped the app, cleared cache and data, and tried again. Exactly like the other phone, no downloads, no progress, keeps circling.
        I suspect something to be wrong with it, since the Friday update.
        One is Android 10 on a CAT S52, the other is Android 12 on a Huawei P30 Pro
        Both plenty of memory left and no SD cards in play.
        MarcM 1 Reply Last reply
          MarcM
          MarcM
          MarcM
          @Con-Hennekens Same experience, deleted the app, and reinstalled the app again, problem solved
            Huh... I am trying this download at work now, and it seems to succeed...
            Is it possible there was a service interruption at the server end yesterday?
              @Con-Hennekens not very likely πŸ™‚
              I actually had to update my own offline maps yesterday (NL, DE, BE, LU) and it took quite long, the lack of progress was disturbing but it completed quite well eventually πŸ˜‰
              UltraStar 1 Reply Last reply
              • Patrick 3a
                Patrick 3a
                Patrick 3a
                I had also problems with downloading some maps. But than I realized that I activated the offline-mode. When I deactivated the offline-mode, it started to download the maps
                • Patrick 3a Patrick 3a
                  #17
                  @Patrick-3a thanks for mentioning πŸ™‚ This makes me realise I might have forgotten an offline mode check there πŸ˜“
                    @Corjan-Meijerink, I don't consider offline mode set to on relevant to being able to download maps. I think it is better to check for internet connection, en warn that any download will be queued until an internet connection is available.
                      @Con-Hennekens You might not consider it relevant πŸ˜‰ The HERE SDK disagrees. If offline mode is enabled, you simply cannot continue / start downloading offline maps as the SDK isn't allowed to connect to internet at all.
                        @Corjan-Meijerink, Well, then I think you should email them about their "brilliant" idea... πŸ˜‰
                          UltraStar
                          UltraStar
                          UltraStar
                          @Corjan-Meijerink I've got to be doing something wrong (iPhone 11P, iOS 16.3.1.)
                          I do not get the errors any more, I did before constantly. Right now, I open Offline maps, download an update, and try to download United States. The Little download circle gets stock somewhere around 12:02 mark. I have deleted app several times, restarted several times, still the same. I have thought that the USA is too large (9GB), so I tried one state, still the same thing. I am giving up on that for now.
                          • UltraStar UltraStar
                            @UltraStar strange. Do you by any chance have offline navigation enabled? If so, that needs to be turned off (in the next update that is checked properly)
                            UltraStar 2 Replies Last reply
                              UltraStar
                              UltraStar
                              UltraStar
                              @Corjan-Meijerink I am sure I don't. I have tried that. When the offline navigation is enabled, I do not even get to the download circle; I get stock on little swirly around the x. It is really bizarre.
                                UltraStar
                                UltraStar
                                UltraStar
                                @Corjan-Meijerink By the way, I try to download at home using the Internet (above picture was taken on the road after few hours of downloading.) The signal and speed are very strong.
                                Theo Lammerts
                                Theo Lammerts
                                MarcM
                                MarcM
                                UltraStar
                                UltraStar
                                Patrick 3a
                                Patrick 3a
                                Greg Meekings 0
                                Greg Meekings 0
                                Ian foster 0
                                Ian foster 0
                                • Testroute segmenten
                                • Hide warnings on the map
                                • Bollard trouble
                                • Minimap
                                  LE DIZES Freddy
                                  LE DIZES Freddy
                                  Erdna
                                  Erdna
