  4. extra waypoints adding,always added at the end of route
21 Posts 11 Posters 279 Views 6 Watching
  • Edwin_M
    Edwin_M
    Edwin_M
    When I create a route on the phone in the app. I usually want to start with a global layout and create more detail and add waypoints in between. But when i do that in the app. Every additional waypoint in the route is added at the end of the route.
    As a result ,you need to ,remember the waypoint numbers and move to the correct position in the route. (Show details,hide details,and again and again)
    I have seen other apps that will use the additional waypoint between the 2 closest waypoints. For me that would be the desired functionality.
    • Jörgen
      You need to add a waypoint on (exactly on) the current route and then you can move this to a new position.
      • Jörgen Jörgen
        @Jörgen said in extra waypoints adding,always added at the end of route:
        No, that won't work. Topic starter is right. When using the mobile app and adding a new waypoint between two existing points, that new waypoint wil be added as the new finishpoint! In the desktopversion of MRA that same action creates a waypoint between those existing points.
        Jörgen 1 Reply Last reply
          This is indeed a bit hard (impossible) on mobile devices.
          Lynchy67 Hubert Thoring Edwin_M 3 Replies Last reply
            Lynchy67
            Lynchy67
            Lynchy67
            If your mobile device happens to be an 12.1” iPad Pro its easy peasy. 🤡
            All joking aside, the iPad Pro is brilliant device for MRA use.
            You get the full desktop experience in a compact form that takes up practically no space when out on tour.
            Corjan Meijerink Redfltrx Reinhard-32 3 Replies Last reply
            • Lynchy67 Lynchy67
              @Lynchy67 agree with that! I use my iPad quite a lot too 🙂
              Lynchy67 Hubert Thoring 2 Replies Last reply
                @Corjan-Meijerink : Wenn es am Handy gehen würde wäre es sehr gut .. !! Ich denke das werdet ihr auch noch einbinden / ermöglichen .
                Vielen Dank .
                If it would work on mobile it would be very good .. !! I think you will also integrate / enable this.
                Thank you very much.
                  Lynchy67
                  Lynchy67
                  Lynchy67
                  Maybe when using a mobile device there should be a specific "Insert waypoint" button using the cross-hair functionality?
                    @Corjan-Meijerink : Hey Corjan, bei meinem alten iPad Air von 2014 mit ios 12.5.7 geht das auch leider nicht so, gleiches gilt für das iPad 9. Generation ios 16.4 … habe keinen sep. Stift 🖊️ dafür ..
                    Das iPad Air hat auch Menü Anzeige Probleme ..
                    s. Bilder
                    Der eingefügte WP 11 hätte eigentlich einer zwischen 8 und 9 sein sollen
                    Hey Corjan, unfortunately that doesn't work with my old iPad Air from 2014 with ios 12.5.7 either, the same applies to the iPad 9th generation ios 16.4 ... I don't have a separate pen 🖊️ for that ..
                    The iPad Air also has menu display problems..
                    see pictures
                    the inserted WP 11 should actually be between 8 and 9
                      @Rob-Verhoeff said in extra waypoints adding,always added at the end of route:
                      You are right, I was on the desktop version. 😰
                      • Lynchy67 Lynchy67
                        Redfltrx
                        Redfltrx
                        Redfltrx
                        @Lynchy67 oh aren't you just helping me solidify my decision to buy an ipad pro. I have been going back and forth about buying one for a bit wanting something that can travel with me that wasn't a laptop and can be used for route planning, 360 video editing and photo organizing. I'm torn at the moment though hoping that a new refresh of the ipad pro will come out in spring 2024 since the current model is really 5 years old at this point.
                        Lynchy67 1 Reply Last reply
                        • Redfltrx Redfltrx
                          Lynchy67
                          Lynchy67
                          Lynchy67
                          @Andrew-Brown
                          Best money I ever spent was getting the iPad Pro.
                          It’s a no brainier.
                          I have iOS and Android Lifetime accounts I can sync and open both on the same iPad.
                          Save the GPX files on the iPad deploy to iOS and Android.
                          Also LumaFusion is awesome software for recording and editing rides with 2 GoPro’s.
                          Redfltrx 1 Reply Last reply
                          • Lynchy67 Lynchy67
                            @Lynchy67 I use an iPad Pro 11 and an Apple Pencil. This combination works great for route planning.
                            Kindly regards
                            Reinhard
                            Montana 700i and Mac
                            Steve Lynch Lynchy67 2 Replies Last reply
                            • Reinhard-32 Reinhard-32
                              Steve Lynch
                              Steve Lynch
                              Steve Lynch
                              This post is deleted!
                                Lynchy67
                                Lynchy67
                                Lynchy67
                                @Reinhard-32
                                I do have the Apple Pencil but I've never used it for route planning.
                                I'll give it a go.
                                Thanks for the tip.
                                • Con Hennekens
                                  On the desktop you can see a small circle indicating that you are ON the line while hoovering the mouse cursor over the line. On whatever touchscreen that will for obvious reasons NOT be visible if you point your finger at that exact spot...
                                  Maybe it is possible to enlarge the area that is considered to be ON the line a bit, that would make inserting points on touchscreens a bit more accurate and intuitive.
                                  I am not certain the webdeveloper is reading this? But I am guessing they are having their hands full at the moment.
                                  • Lynchy67 Lynchy67
                                    @Andrew-Brown
                                    It’s a no brainier.
                                    Redfltrx
                                    Redfltrx
                                    Redfltrx
                                    @Lynchy67
                                    You are killing me, I really want one but I know there is refresh coming so I'm behaving and not going to get one until that happens.
                                    • Ad V
                                      Ad V
                                      Ad V
                                      It works very simple and efficient, both on phone and iPad: zoom in on the current route, double-click on the route and a new, intermediate, waypoint appears. You can now shift the waypoint to where you want it to be. Am using this all the time, for quite a period already.
                                      • Ad V Ad V
                                        Lynchy67
                                        Lynchy67
                                        Lynchy67
                                        @Ad-V
                                        Yes I agree if you go to the Routelab on a mobile device, it will work as you indicated.
                                        I suspect however, that some users are trying to do it in the Next Beta App which as @Corjan-Meijerink indicated is “impossible”.
                                        Edwin_M 1 Reply Last reply
                                        • Lynchy67 Lynchy67
                                          @Ad-V
                                          Edwin_M
                                          Edwin_M
                                          Edwin_M
                                          Just created a cycling route on Komoot on Android, and it placesthe added waypoint in between points ,in between...not at the end. Exactly as expected
                                          Edwin_M
                                          Edwin_M
                                          Ad V
                                          Ad V
                                          Lynchy67
                                          Lynchy67
                                          Steve Lynch
                                          Steve Lynch
                                          Redfltrx
                                          Redfltrx
                                          • Strange translation
                                          • Crazy routing
                                          • Shared toggle switch
                                          • Undo/Redo tool is hidden
                                          • google street view volledige boord zichtbaar maken.
