  4. Verschil tussen mijn gemaakte route en de navigatie
3 Posts 3 Posters 66 Views
  • philippe 0
    philippe 0
    philippe 0
    Re: Route changes between planned & navigate
    Op de foto met rode lijn is de gemaakte route, en de navigatie maakt er iets anders van ?3CBF73EE-C1E1-4889-A8AA-5F1948B3C6F4.jpeg
    • Tim  Thompson
      Tim  Thompson
      Tim Thompson
      Sure... It's common and why you need to verify the route on the target navigation device before navigating.
      Off the top of my head... Some things that can minimize the discrepancies...
      1. Make sure you are using the same map data in the route planner that is used on the target device. If MyRoute-app Mobile or MRA Navigation... Then HERE.
      2. Judicious placement and number of waypoints to prevent the mobile app's routing engine from deviating. Make sure waypoints are placed on roads. For example... In this case... maybe move route-point 5 down the road a bit.
      3. Are the routing options/settings the same in the route planner and mobile app? Recommendation... turn them all off.
      4. Verify mobile app route using track overlay. Adjust as necessary. If the above steps were done, I would guess that there should be very few - if any - adjustments needed.
      • TorqueRider
        The situation is difficult to judge if you do not see the position of point 6.
        If TS wants to be helped optimally, it is better to post a link to the route (with privacy setting on Public.
        philippe 0
        philippe 0
        Tim  Thompson
        Tim Thompson
          142
        • Route exporteren uit beta
          Johan 5q
          Johan 5q
          120
        • SilverFox Controller C2
          Hans Lamers
          Hans Lamers
        • "Please verify your email" display
        • Layers menu: option to permanently display Favorite labels
