  4. Discussion: Carplay / Android Auto motorcycle device tested
53 Posts 10 Posters 550 Views 1 Watching
    This is a vivid discussion 😉 . I am sorry but I didn't read it completely. TL;DR and too much of the same arguments. I do however have a few comments, maybe it gives some extra brain fuel.
    I think it would indeed be very handy to have a battery in the device, exactly to overcome the reset/re-initialization each time after starting your bike. Also I like to set my route often before putting it on the bike. A small battery would suffice for that. I owned a Streetpilot many years ago and the biggest frustration was: no-battery...
    In my opinion the comment about hot/cold battery problems is a non-issue. ALL Zumo and Rider users would have problems with their batteries if it was, but instead most units survive more than 10 years of use.
    I am in favor of connecting accessoires directly to battery. You can prevent power-leakage with a simple switch. You can depend on CANBUS to switch accessories off, but is a proven fail-sensitive method. I had an USB charger keeping CANBUS open, dead battery in 3 days. Besides that, direct attached and manually switched I can use my USB charger to charge my COM set while drinking coffee 😉
    I like the idea of an dedicated Android navigation device. For me it doesn't really add anything if it does that through Android Auto, screencast or whatever. An autonomous device (like a phone without phone-functions) with an decent integrated powered mount like a Zumo would be perfect. Basically a Zumo running Android with the Google playstore is perfect.
    Tim  Thompson
    Tim  Thompson
    Tim Thompson
    #38
    @Con-Hennekens said in Discussion: Carplay / Android Auto motorcycle device tested:
    As I mentioned... I think an internal battery is unnecessary. I doubt I would want to spring for any additional cost/complexity to have it.
    Comparing purpose built/designed motorcycle nav devices with general purpose smartphones is a bit like comparing apples and oranges. I don't think that there is any doubt that heat is an issue with smartphone batteries, particularly when the phone is used in less-than-ideal conditions (car dashes, direct sunlight, etc.) while running navigation apps. Also... winter riding and trying to power a smartphone in the cold is probably a non-starter. First, in my experience, when the phone is operated in the cold (think of a mounted phone exposed to cold wind) it's charging rate (greatly diminished) won't keep up with the power demand of running a navigation app. Second, charging cold lithium batteries is supposedly detrimental to the battery/not recommended.
    Granted... these AA/CP devices would likely fall into the purpose-built category (like a Zumo). Still, I'd rather not have any battery issues/nonsense if I could get away with it. Apply the KISS principle when possible and keep it cheap.
    HD provides (on my bike) both switched and fused direct battery power interfaces for accessories. I would simply use these (switched in this case).
    Indeed, this would probably be a good option. However, AFAIK, no such solution exists.
    • Tim  Thompson Tim Thompson
      @Tim-Thompson said in Discussion: Carplay / Android Auto motorcycle device tested:
      I don't consider a battery to be complex. It prevents a lot of unnecessary reboots, and makes it possible to use the device to preload your ride still behind your coffee without the need to take out your phone. I consider that basic functionality.
      It's still just about a battery...
      That sound as direct as it gets 😉
      • Tim  Thompson
        Tim  Thompson
        Tim Thompson
        So I've done some initial testing with my unit (BINIZE variant).
        Start up to CP with navigation app loaded (in this case Scenic)... 30 seconds every time. No failures, No issues. So far no need to repeat pairing. This thing has worked fine so far.
        About having the navigation and route queued up and ready before stepping out to the bike. No problem, queue it up on the phone. Apply power to the unit and 30 seconds later you're ready to navigate. If starting the bike power cycles the unit, no big deal, the phone still has the nav app running. So, the unit will be up and ready to navigate in 30 seconds after engine start. Seems reasonable to me.
        • flamingm0e flamingm0e
          @Jure-Sirena-0 said in Discussion: Carplay / Android Auto motorcycle device tested:
          I also tested heavily garmin zumo xt. Nice device but management of device is very difficult, you need laptop with you….
          You don't need a laptop to use a Zumo XT. I haven't connected my Zumo XT to my computer in months. It works 100% wirelessly.
          Jure Sirena 0
          Jure Sirena 0
          Jure Sirena 0
          @Matt-Flaming You cannot manage routes on the fly with app. Cant you, you speak about import / export mainly. I speak about management of already preapred routes. This is where MRA and Tomtom drive are the best.
          MRA - you open route changes are saved asap - you GO
          Tomtom Drive app, you open route, change, delete, move....click sync with device, new (or old) route already awaits on device (without touching GPS device)
          This is my point
          flamingm0e 1 Reply Last reply
            How do you mange large routes - especially on trip. Well MRA route planner is answer but with garmin itself?
            What do you mean?
            Create the route. Open the route in Explore on your phone and it syncs automatically. Or open it with Drive and send it to the Zumo. I don't connect my Zumo to my computer at all unless I want to play around with Open Street Maps or themes.
            In fact, my Zumo is locked on my bike nearly 100% of the time.
            Jure Sirena 0
            Jure Sirena 0
            Jure Sirena 0
            wrote on last edited by Jure Sirena 0
            #42
            @Matt-Flaming This is my point - not import, export but change / management of routes while on the trip / being mobile - and for that you almost need a laptop....because there is nothing interactive at Garmin
            But I have a feeling Garmin explore for Andrpoid is different then the one for iphone. I cant manage almost anything with app on iphone
            • Jure Sirena 0 Jure Sirena 0
              This is my point
              flamingm0e
              flamingm0e
              flamingm0e
              Sure you can.
              You can use MRA, and send it to Explore or Drive using the phone app.
              Again, OPEN the route in Drive or Explore....it will send directly to the Zumo...
              It's not. I use both. Really simple to sync new/updated routes.
              Jure Sirena 0 1 Reply Last reply
              • Bas Greve
                Bas Greve
                Bas Greve
                Zijn er al ervaringen met deze https://www.amazon.nl/Motorfiets-Navigatie-Fodsports-Waterdicht-Bluetooth/dp/B08LHDR9F1
                Dat is wel een GPS. Het lijkt me handig. Route maken op de PC. Inloggen op het device op MRA en direct vertrekken
                  Sure you can.
                  Jure Sirena 0
                  Jure Sirena 0
                  Jure Sirena 0
                  #45
                  @Matt-Flaming Ok I get it, using 2-3 apps. Its actually what I ment.
                  Nevertheless I cant edit routes in explore I only have rename and edit colours....no way to open existing route and work on it, yes for MRA of course, that I get it
                  on top.......I really cant do anything with explore, except import
                    flamingm0e
                    flamingm0e
                    flamingm0e
                    I never said anything about editing in Explore....
                    Edit route in MRA. Open route with Explore. It syncs with Zumo. It's literally that simple. You're making it out to be something it isn't.
                    But I'm done with this conversation because you're not going to grasp what I'm saying without trying it.
                      Jure Sirena 0
                      Jure Sirena 0
                      Jure Sirena 0
                      @Matt-Flaming
                      Oh I have zumoxt (4 bikes with them)
                      Sorry not to get my point. I understand using more apps but that was not the point
                        @Matt-Flaming
                        flamingm0e
                        flamingm0e
                        flamingm0e
                        You're not using more apps...
                        Seriously, OPENING the route in Explore creates a collection. That collection AUTOMATICALLY syncs to the Zumo. So it's one step, the same as ticking a box in MyDrive. Open the route in Explore, it syncs, you have your new route right there.
                        OR
                        Open it in Drive, and "send to zumo"...DONE. It's not like you're editing the thing in a different application. You're just initiating the sync.
                        • Jure Sirena 0
                          Jure Sirena 0
                          Jure Sirena 0
                          The final verdict of my problem:
                          After testing 3 iphones, it was clear it only happened on mine. It is now confirmed, that everytime I connect carplay with my phone in car, it will not connect to device next time.....
                          Dealer says it is ios problem and doesnt want to support the issue. It is clearly device problem, as my phone has no problem with the 2 cars we have at home. It switches between then flawlessly.
                          but as soon as I connect to device with new pairing procedure, it will work for days, moths or minutes until I connect same phone to carplay in any of the cars. After that device needs new pairing OR manual activation of SPP option under the BT menu of paired phone....
                          So its clearly device problem. I sold it today for 50€. Crap.
                            Tim  Thompson
                            Tim  Thompson
                            Tim Thompson
                            Not that it matters anymore...
                            But it sounded as if the common denominator was your phone.
                            I have no problem with my iPhone, CP and going back and forth between my car and this device. So far it has connected to both automatically without fail or issue.
                            Did you try the same experiment with the other iPhones? Were the other iPhones able to go between the cars and this device without issue?
                              Jure Sirena 0
                              Jure Sirena 0
                              Jure Sirena 0
                              #51
                              @Tim-Thompson 1 x iphone 13 pro, 2 x iphone X (in begining of my post I ment I knew why it was happening to mine, because I was able to replicate it on all 3)
                              same issue
                                same issue
                                Tim  Thompson
                                Tim  Thompson
                                Tim Thompson
                                same issue
                                Oh... So you are saying that all 3 iPhones tested had troubles going back and forth between your cars and this device? All 3 phones would connect to your 2 cars without issue, but all 3 phones would fail to connect to the device after being connected to one of your cars?
                                If I understood that correctly... Don't know what to tell ya. Doesn't matter anyway... You've already made the problem go away... Just not in the way one might prefer.
                                  same issue
                                  Jure Sirena 0
                                  Jure Sirena 0
                                  Jure Sirena 0
                                  @Tim-Thompson yes thats it.
                                  Vlad Popovici 0
                                  Vlad Popovici 0
                                  Bas Greve
                                  Bas Greve
                                  flamingm0e
                                  flamingm0e
                                  Bart 4
                                  Bart 4
                                  Jure Sirena 0
                                  Jure Sirena 0
                                  Tim  Thompson
                                  Tim Thompson
                                  • Testroute segmenten
                                  • Bollard trouble
                                  • Hide warnings on the map
                                  • Minimap
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    Erdna
                                    Erdna
