  2. Routes & Tracks
  3. Disable seasonal closures
26 Posts 5 Posters 14.5k Views
  • paul69 paul69
    hi,
    I must comment, this was an interesting thread, as I had the same problem when I opened my routes later in the year to the Austrian Alps, they had changed, I presumed this was due to road closures etc.
    this thread changed to a native language, yes I know I could copy and paste into google translate. but I have no idea if there is a fix, or an answer.
    can I ask, when you save a route, there seems to be a possibility that it will change each time you open it.
    if I saved the route to a file on my computer and then reimported it at a later date would it be the original or will it change to suit the road closures on that particular day etc.
    OR
    If I send the saved route to a friend via email, there is a good chance that the original planned route would not be the same.
    this is definitely something I will need to be aware of in the future.
    this does seem strange, but I imagine it's beyond the fix for the MRA gang.
    I do have "disable seasonal closures" ticked
    @paul-69
    There are indeed all kinds of influences that can change a route. Not just seasonal closures. Roadworks and other temporary measures may be included in the maps (if known to the mapmaker). But the traffic situation on the spot may also have changed permanently.
    In addition to the route, I almost always save a track of the route in MRA. This way I can check the route and adjust it as best as possible to the original planning.
    If you share routes, you always have to take into account that the recipient may eventually have a different route. For example by using a different type of navigator or different map version.
    paul69 1 Reply Last reply
    • TorqueRider TorqueRider
      @paul-69
      #22
      @Jack-van-Tilburg said in Disable seasonal closures:
      hi @Jack-van-Tilburg, thanks for quick response,
      it is definitely something to be aware of, a planned route may not necessarily be the same when reopened a few weeks later,
      out of interest, excuse my ignorance, how do you automatically save a track to MRA,
      when I save a route as .gpx 1.1 (track, POI) it downloads to my computer, I then have to import it back into MRA, where it would then show in "my routes" as a Route-track.
      is this the correct way of carrying out this task
      K1600 GTL
      iPhone 13 Pro, carpuride 702b
      • paul69 paul69
        @paul-69
        Unfortunately that is the way ☹️
          @paul-69
          thanks @Jack-van-Tilburg
          Unfortunately that is the way ️
          this is not a problem, I was making sure there was no other way.
          this may well become my new routine now, when complete, save as track for reference.
          K1600 GTL
          • paul69 paul69
            @paul-69, The beta of the "Next" navigation tool is heading in a direction where it is able to navigate trackbased. So there is suddenly A LOT more interest for a function that copies your route to a track without the above workaround. I presume the track-functionality of the (online) planner will head in a direction that is more suitable to the use of tracks too, in due time.
              thanks @Con-Hennekens will look forward to the update.
              K1600 GTL
              Paul Pals
              Paul Pals
              Silvano Besana
              Silvano Besana
              • Elevation profile: cursor that follows the route on the map
              • Question on Beta access
              • Add "Upload File"
              • Totaaltijd veranderd niet
                Gerard Caspers
                Gerard Caspers
              • Device Limit – There Are Limits to My Understanding
                BMcG
                BMcG
              • A to B Navigation with Extra Stop.
