  4. Tap to enable.... changes global setting
5 Posts 3 Posters 1.4k Views 2 Watching
  • Herman Veldhuizen
    Herman Veldhuizen
    Herman Veldhuizen
    This tap changes the global setting to enable automatic recalculation. This has annoyed me a number of times. It should in my opinion only change the setting for the current running navigation.
      @Herman-Veldhuizen automatic recalculation is one of the default settings by design. It works differnt then the recalculation modes in Garmin and TomTom IT WORKS. So my advise would be set it to default
        Herman Veldhuizen
        Herman Veldhuizen
        Herman Veldhuizen
        @Marinus-van-Deudekom The question is not what the default should be. In my job i sometimes deviate from the planned route on purpose and are not interested in new recalculations. The question is for how long recalculations should happen. As it is now it will happen 'forever' (also for other routes which I drive at later times). More logical is a one time recalculation or as long as one isn't back on the planned route.
          It will be changed so that tapping there does one recalculation 🙂
            Herman Veldhuizen
            Herman Veldhuizen
            Herman Veldhuizen
            @Corjan-Meijerink Thanks.
            Herman Veldhuizen
            Herman Veldhuizen
              453
            • Myrouteappstay
            • Track colors by section.
              Rolf Engelsman
              Rolf Engelsman
              Marcel Versluis
              Marcel Versluis
