  4. CarPlay and Android Auto device
64 Posts 9 Posters 1.0k Views 2 Watching
  • Jure Sirena 0 Jure Sirena 0
    @Tim-Thompson I tried that port, was same, its easier to continue work in cradle. Now able to reproduce it I think I understand it, and I might even be able to fix it with my (very basic) developer skills
    Please be so kind and let me know if your setting (by default) is ON or OFF:
    device settings / bluetooth / paired / 'select your paired iphone' /
    HFP on or off?
    A2DP on or off?
    and the one I am interested in particular SPP on or off?
    Many thanks
    Tim  Thompson
    Tim  Thompson
    Tim Thompson
    @Jure-Sirena-0 said in CarPlay and Android Auto device:
    HFP on or off?
    A2DP on or off?
    Many thanks
    All profiles are set to off on mine.
    Jure Sirena 0 1 Reply Last reply
    • Tim  Thompson Tim Thompson
      HFP on or off?
      A2DP on or off?
      Many thanks
      Jure Sirena 0
      Jure Sirena 0
      Jure Sirena 0
      @Tim-Thompson
      As expected. Before confirming I might found a fix, i will try first few power ups after the night
        @Tim-Thompson
        Jure Sirena 0
        Jure Sirena 0
        Jure Sirena 0
        @Jure-Sirena-0 After 3 days of testing we found out it happens on my iphone 13 Pro while not on my sons Iphone X
        both are 16.3.1 ios...
        now this one is tough to crack...
        • Tim  Thompson
          Tim  Thompson
          Tim Thompson
          So I've done the permanent install. Wired the power supply into the bikes switched accessories power via this kit...
          Electrical Connection Update Kit
          Routed harness to the right side of the bike and installed the power supply there...
          Wiring routed up through the backbone of the frame and out the left side...
          Display mounted. Phone resides in windshield bag with power routed to it from the USB port.
          The red arrow points to a Chargie...
          https://chargie.org/
          As mentioned before... The Chargie manages battery charging and temperature. AFAIK there are generally two ways to get this kind of control... Software which requires rooting the phone and this hardware approach. The Chargie works pretty well for this task.
          Overall I'm pretty pleased with this setup. The phone (battery/heat/cold/elements) won't get stressed and the CP/AA display works great. I've tried an intercom system with it. Everything pairs and works as expected. As discussed before.. Some had mentioned that they don't like that the display unit doesn't have an internal battery to prevent power cycles/reboots when you start the bike etc. This has absolutely not been a problem. The display unit powers up and reconnects to everything within 30 seconds. If you had a Nav session going before shutdown (say stopping for gas), the route/navigation session is still there when the system reboots and reconnects.
          The only nit that I've found so far is that the BINIZE unit's firmware version doesn't yet have the Android Auto volume controls. Other "brands" have already provided the firmware update for that. Right now I'm using my iPhone, so it's not a problem. But sooner or later, I'll want to update the firmware.
          • 4
          Dae 0
          Dae 0
          Jure Sirena 0
          Jure Sirena 0
          Tim  Thompson
          Tim Thompson
          • MRA Studio export speed
          • Hiya from UK
            Russ Nattrass 1
            Russ Nattrass 1
          • geeft routepunt niet weer
