  4. Routes Changing when you hit start!
3 Posts 2 Posters 88 Views
  • alan cooksonundefined Offline
    alan cookson
    We have just tested the app on a driving tour in Wales for 3 days, however on all 3 days when we selected our routes the pre planned route changed!
    It came up with a +(mins) in yellow and altered our planned route quite considerably on 2 of the days, which seems completely against the rationale of what you are trying to achieve.
    When we loaded the tracks into tom tom that we give to our customers the routes were as per the track we exported via tomtom my drive, so cant really understand why it would change them!
    hope it helps as we really want this to be the answer to us having to keep using the tom tom units, we would much rather get our customers onto the myroute app for our events, but we need to know its not going to change our routes based on traffic etc.
    Maybe it could have an ignore traffic and maybe road closures toggle switch in settings?
    hope it helps and keep up the great work we love using the planning tools
    happy to share our routes with you guys if that helps as well πŸ™‚
    cheers Alan
    GTTourz
    • alan cooksonundefined alan cookson
      cheers Alan
      GTTourz
      @alan-cookson Thanks for your message. This behaviour has been observed by others too.
      The answer is indeed quite easy. The first cause is the traffic. This is now enabled by default and can’t be turned off (see Navigation preferences in the app). In a future update, this can be turned off. This would reduce the chance of the app generating a different route.
      The other reason is that the app uses a significantly newer HERE version. The website is on a slightly older version which can also be the reason for different calculation results between the app & website. This be fixed later on before the final release.
      Anyhow, the only way to prevent this issue for now is to place a bit more shaping points πŸ™‚
      alan cooksonundefined 1 Reply Last reply
        alan cookson
        @Corjan-Meijerink thanks very much for the detailed reply, i did think it may be the traffic situation. We look forward to the later release, we have no more tours until April so maybe by then it will be closer to the finished article.
        The reason we dont like too many shaping points is we use the waypoint list in the road book which works rerally well doing a print screen off the pdf route πŸ™‚
        keep up the great work, love this product!
        cheers
        Alan
        • Corjan Meijerinkundefined Corjan Meijerink locked this topic on
        alan cookson
        • Joining a planned route from a differant position.
          coupe_vsundefined
          coupe_vs
          471
        • Rijrichting in route
          1.4k
        • sorting of routes by departure date
          Lex.Kloet.RXundefined
          Lex.Kloet.RX
        • running myRoute-app on a carpuride
          Nick Carthewundefined
        • Offline Navigation
        • Problemen route opslaan naar plan.tomtom
        • Exporting route from app to Garmin XT webpage not available
        • bochten classificatie
