  4. MRA notifying me of something?
8 Posts 3 Posters 2.4k Views 2 Watching
  • Ton Machielsen
    Ton Machielsen
    Ton Machielsen
    When I am using MRA in the car or on the bike, always with Apple CarPlay, I get a notification every 500m, half a minute, not sure what the trigger is, but I hear the notification constantly. I’m almost sure this comes from MRA since I started hearing this since I installed MRA, never heard it before.
    It’s annoying not only because it interrupts music and comms, but also because the family asks if I can either switch it off or disconnect my phone from CarPlay.
    I’ve been going around the app multiple times to see what is still sending notifications, but I haven’t figured it out.
    Am I the only one having this problem?
    MRA 4.3.4 375 with iPhone 14 Pro Max and Nissan (car) and MTC-10 (bike) head unit.
    • Ton Machielsen Ton Machielsen
      @Ton-Machielsen did you configure the voice instructions to be a beep?
      Ton Machielsen 1 Reply Last reply
        Ton Machielsen
        Ton Machielsen
        Ton Machielsen
        @Corjan-Meijerink said in MRA notifying me of something?:
        @Corjan-Meijerink I can only reply once per hour. I sent you a couple of chat messages.
          @Ton-Machielsen you should be able to reply more often now.
          Are you sure the notifications are from our app? If you have voice prompts turned off, there aren’t much “hidden” notifications.
          You might get warnings about certain route restrictions but that would also be visually displayed so that would be logical notifications.
            Ton Machielsen
            Ton Machielsen
            Ton Machielsen
            @Corjan-Meijerink Still trying to find that out. That's why the question. It started happening once i installed the MRA, but this may be a coincidence.
            Greenham 1 Reply Last reply
              Greenham
              Greenham
              Greenham
              @Ton-Machielsen
              For sure check you settings for voice prompts. I had them turned on at first and it drove me crazy for all the reasons you cite. It seems now you can differentiate what gets a voice prompt and what doesn't.
              To be sure, ACP/AA also do some strange things when in the navigation app. I am not a fan of the microphone using your voice to communicate. Every little noise triggers the mic to open. I'd rather it be Push to Talk.. My point isn't to solve my problem but to demonstrate that AA in my case does stuff completely unassociated with MRA/Nav.
              • Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                Ok, i still owe the developers a response. It was Radarbot notifying me that i was over the speed limit. Nothing to do with MRA. Sorry for the inconvenience caused.
                I do have another issue though. I will open a new ticket for this.
                  @Ton-Machielsen Thanks for letting me know 🙂
                  Greenham
                  Greenham
                  Ton Machielsen
                  Ton Machielsen
                    Alderweireld Rudi 0
                    Alderweireld Rudi 0
                    104
                    Hanza 0
                    Hanza 0
                  • Weather as a service
                  • Map Layers
                    Don Stauffer
                    Don Stauffer
                    Andy Smith 5
                    Andy Smith 5
