Date of uploaded tracklog
I uploaded a gpx file as a tracklog that I created with another app. In the tracklog, in the field "Datum" the date of the import is displayed, not the date when the track was recorded; In the gpx file, date is stored in the format "2023-10-02T07:10:13.14".
Is a specific date format required when importing a gpx file?
@Thi-Lo, I don't think so. An imported file just gets today's date, since it's created today. Actualy it's a "last edited" date, so anything you do after import will update that date (and time).
Hi, I am not sure if I understand your problem correct. But may be gps-Babel could help you to change or correct the time stamp in your file, take a look.
@Jörgen Thanks for the tip with gps-babbel. I had uploaded different gpx files with different recording dates, the import date was always displayed - regardless of when the track was recorded.
@Thi-Lo ok, it was a try.
