  2. Routes & Tracks
  3. Routes Des Cols
Routes Des Cols
7 Posts 3 Posters 2.4k Views 1 Watching
  • Martin Proudlove
    Martin Proudlove
    Martin Proudlove
    Hi All. I am looking to do the Route des Cols, across the Pyrenees. I can find the route on several website but I am not able to get them on to MRA.
    Any help is gratefully received.
    • Martin Proudlove Martin Proudlove
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Martin-Proudlove
      Check out the MRA RouteXpert Library I'm sure you'll find some there.
      https://www.myrouteapp.com/en/library/countries
      Martin Proudlove 1 Reply Last reply
      • Steve Lynch Steve Lynch
        @Martin-Proudlove
        Martin Proudlove
        Martin Proudlove
        Martin Proudlove
        @Steve-Lynch Hi
        I had a good look but could not see anything.
        Steve Lynch 2 Replies Last reply
          @Steve-Lynch Hi
          Steve Lynch
          Steve Lynch
          Steve Lynch
          @Martin-Proudlove
          In that case you can import the routes you have found on the web into MRA, presuming they provide the GPX files.
            @Steve-Lynch Hi
            Steve Lynch
            Steve Lynch
            Steve Lynch
            @Martin-Proudlove
            Route Des Cols.
            https://www.myrouteapp.com/en/social/route/6774984?mode=share
            Skellum 1 Reply Last reply
              @Martin-Proudlove
              Route Des Cols.
              Skellum
              Skellum
              Skellum
              wrote on last edited by Skellum
              @Steve-Lynch @ I wonder if the routes that Martin is trying to load on to MRA are routes affected by seasonal closures?
              • Skellum Skellum
                Steve Lynch
                Steve Lynch
                Steve Lynch
                @Skellum
                Yes, the Here map shows a break in the route at Waypoint 40 and 41.
                Tom Tom and OSM however allows the route through.
                This is not a route I have driven myself I just found a GPX on the the web to demonstrate Uploading for @Martin Proudlove.
                Definately a route I will be doing at some point however.
                Skellum
                Skellum
                Martin Proudlove
                Martin Proudlove
                Steve Lynch
                Steve Lynch
                • 'Geen adres bekend'
                  PA. Vis 0
                  PA. Vis 0
                  Ruud Bijkerk
                  Ruud Bijkerk
                • Route exporteren uit beta
                  Johan 5q
                  Johan 5q
                  127
                  156
                • iPad - zooming out
                  Big Al 1
                  Big Al 1
