    • Search
    • Awards
    • Tags
    • Users
    • Groups
    Routes Not Loading
    [Web] Problems, Bugs and other Issues
    151
    Loading More Posts
    • Chris English
      Chris English last edited by
      Routes Not Loading
      Seriously!!? Guys, what is going on (both the desktop and iPhone versions)? The Routes will not load, in spite of re-boots, re-connection to the Internets etc etc. We relay on this app for critical navigation, and this needs to function flawlessly, 100% of the time, all the time.
      Rens De Haan Marinus van Deudekom Corjan Meijerink 3 Replies Last reply Reply Quote 0
      • Rens De Haan
        Rens De Haan @Chris English last edited by
        @Chris-English i have the same problemens
        1 Reply Last reply Reply Quote 0
        • Hathi
          Hathi last edited by
          Same problem. Even with very old routes none them are loading
          • bastiaens harry
            bastiaens harry last edited by
            Hier zelfde probleem, heeft er iemand een oplossing aub
            1 Reply Last reply Reply Quote 1
            • Marinus van Deudekom
              Marinus van Deudekom @Chris English last edited by
              @Chris-English tried both Android and iOS
              No problems at all. The app is working perfectly
              Garmin XT
              Samsung S20FE mounted on a Quadlock
              Chris English 1 Reply Last reply Reply Quote 0
              • bastiaens harry
                Marinus enig idee wat het probleem zou kunnen zijn?
                Marinus van Deudekom 1 Reply Last reply Reply Quote 0
                  Marinus van Deudekom @bastiaens harry last edited by
                  @bastiaens-harry gebruik je de app of de web versie via een pc
                  Garmin XT
                  bastiaens harry 1 Reply Last reply Reply Quote -1
                  • Chris English
                    Chris English @Marinus van Deudekom last edited by
                    @Marinus-van-Deudekom Odd, thanks for testing. Seems it's impacting some users and not everyone....
                    • bastiaens harry
                      bastiaens harry @Marinus van Deudekom last edited by
                      @Marinus-van-Deudekom web versie
                        @bastiaens-harry ga die ook nog ff proberen
                        Garmin XT
                          Marinus van Deudekom @Marinus van Deudekom last edited by
                          @Marinus-van-Deudekom ook de web versie geprobeerd, geen enkel probleem. zowel een route die ik vandaag heb gemaakt als een van afgelopen juni openen zonder problemen.
                          Garmin XT
                          bastiaens harry 1 Reply Last reply Reply Quote 0
                          • bastiaens harry
                            @Marinus-van-Deudekom bij mij werkt er niets ook de app niet op mijn iphone, enig idee wat ik kan doen of bij wie ik terecht kan
                              @bastiaens-harry wat voor een abonnement heb je of gebruik je de basic versie
                              Garmin XT
                              bastiaens harry Chris English 2 Replies Last reply Reply Quote 0
                              • bastiaens harry
                                @Marinus-van-Deudekom gold, kunnen we misschien even face time
                                Hoanemans 1 Reply Last reply Reply Quote 0
                                • Hoanemans
                                  Hoanemans @bastiaens harry last edited by
                                  Hier worden routes ook niet geladen. Ik heb basic met de navigatie als trail..
                                  • Chris English
                                    @Marinus-van-Deudekom Gold/Navigation, upgraded and paid yesterday. When attempting to load the Route, it complains that the route is too long, and the I should shorten it, even for a route that 128 miles! It then loads some of the Waypoints only and not the actual route or the milage information. You cannot make any changes to the route, which then tries to re-load and goes into the never-ending load cycle. This seems like the server cannot process the complete transaction, and only loads a corrupted version in the UI (I am using the web version). This may also explain why some users, like yourself are not having any issues, but others are - perhaps some of the servers are overloaded and pinging, too many transactions or overload due to bad server balancing, or may be one particular server is having an issue.
                                      @Chris-English maybe you can share the route so we can help you or at least test the route
                                      Garmin XT
                                      • tjackson125gmail.com
                                        tjackson125gmail.com last edited by
                                        All old routes have disappeared from my smartphone, but are still showing on my PC, but without any routelines between waypoints. After trying to load any route, a message appears saying"The route calculation seems to take very long. You can try resolving this by shortening your route or by adding a waypoint between your current waypoints."
                                        • Chris English
                                          @Marinus-van-Deudekom I just made one route "Public", it's called 03. Chile
                                          • Chris English
                                            Chris English @tjackson125gmail.com last edited by
                                            @tjackson125gmail-com Yes, EXACTLY the same here! 😞 😞
                                            • 1 / 2
                                            • WoMo zB 3,5t oder 7,5t oder .. zu viele Anzeigen braucht man nicht wirklich
                                            • CarPlay audio problem and fix for Corjan…
