Changing the order or routes within a folder
Hello.
I have created a folder and within that folder there are 21 routes which are 21 days of a planned holiday.
Each folder is titled day 1 , day2 etc. etc. I would like to have some sense of order ie day1 at the top followed by day 1 and day3 etc working down the folder. Unfortunately Mt Route has randomly ;listed the days in any old order.
My question is
Is there any way of changing the routes within the folder to show them in some sense or order?
I hope someone can help.
Thanks
Chris
Give the routes a specific name. That allows to sort in alphabetic order.
@Chris-3u Your routes are not listed in 'any old order' they are listed according to what preference you have set. You can choose to sort by using any of the headings, but if you want them sorted by name, I suggest starting them A1, B2, C3 etc or as @Reinhard-32 suggests above.
I also have a question about sorting, please have a look at my example:
I can'get it to sort 1, 2, 3 etc.
Kind regards, Kees
@Kemille It won't because of the way the numbering works. It will choose 1 first then 10 then 100 etc. Rename them as A1 B2 C3 and it will sort in order.
@Nick-Carthew
Alternatively you can use 2 digits:
01
02
03
09
20
21
Then you will get the correct sorting.
@Reinhard-32 Of course
A much simpler way
@Kemille Hi Kemille.
I had the same problem. Instead of putting the number 1, try putting 01
it worked for me
@Reinhard-32 Hi. That was a big help. Many thanks
Thanks all! It works
@Reinhard-32 Wow.Many thanks
