<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Disabling seasonal closures does not work with Here map]]></title><description><![CDATA[<p dir="auto">I want to create a route on the website using the Here map and have deactivated the "seasonal closures".<br />
The route goes via the Nockalmstrasse, among other places, but despite the selected setting, a detour via the Turracherhöhe is always chosen.<br />
Am I doing something wrong or is this an error in the planning tool?</p>
<p dir="auto"><img src="/assets/uploads/files/1741589045717-e2394ca7-e5ad-4a9b-bc5f-ef606d1ac40a-image.png" alt="e2394ca7-e5ad-4a9b-bc5f-ef606d1ac40a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://www.myrouteapp.com/de/social/route/10672011?mode=share" rel="nofollow ugc">https://www.myrouteapp.com/de/social/route/10672011?mode=share</a></p>
]]></description><link>https://forum.myrouteapp.com/topic/8888/disabling-seasonal-closures-does-not-work-with-here-map</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 10:32:48 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/8888.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Mar 2025 06:44:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Disabling seasonal closures does not work with Here map on Mon, 10 Mar 2025 09:00:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j%C3%B6rgen" aria-label="Profile: Jörgen">@<bdi>Jörgen</bdi></a> Hallo Jörgen, danke für die schnelle Antwort.<br />
Ich habe gestern schon mehrfach die Punkte verschoben, dann hat es gepasst aber beim nächsten öffnen der Route hat es dann wieder nicht gestimmt.</p>
<p dir="auto">Ich hab nun noch mehrere Punkte auf der Nockalmstrecke eingesetzt ( an dieser Stelle passt das jetzt) ABER korrekt ist das meiner Meinung nach nicht!</p>
<p dir="auto">Wenn ich jetzt die saisonalen Sperrungen aktiviere, dann geht die Route trotzdem über die Nockalm aber die anderen Pässe werden blockiert so wie es sein sollte.</p>
<p dir="auto">Bitte sei so nett und nimm mal den Hacken bei Sperrungen raus und mach Dir selber ein Bild.</p>
<p dir="auto"><img src="/assets/uploads/files/1741594002787-4d249042-620f-4aa3-8f5d-e1a6e1bda5c7-image.png" alt="4d249042-620f-4aa3-8f5d-e1a6e1bda5c7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Zum Vergleich hier noch die identische Route berechnet in Tom Tom.<br />
Nach meinem Verständnis sollte das so auch in Here funktionieren</strong></p>
<p dir="auto"><a href="https://www.myrouteapp.com/de/social/route/10685894?mode=share" rel="nofollow ugc">https://www.myrouteapp.com/de/social/route/10685894?mode=share</a></p>
<p dir="auto"><img src="/assets/uploads/files/1741597251122-673ab92c-e500-494e-8ec8-f7b680651e0c-image.png" alt="673ab92c-e500-494e-8ec8-f7b680651e0c-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/post/60819</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/60819</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Mon, 10 Mar 2025 09:00:54 GMT</pubDate></item><item><title><![CDATA[Reply to Disabling seasonal closures does not work with Here map on Mon, 10 Mar 2025 07:03:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter-zehentreiter" aria-label="Profile: Peter-Zehentreiter">@<bdi>Peter-Zehentreiter</bdi></a> If you move WP 23 a. 24 it works, may be add another WP.</p>
<p dir="auto"><img src="/assets/uploads/files/1741590230122-57f5fc6e-cbba-4eea-8d36-1c0e9e907a22-image.png" alt="57f5fc6e-cbba-4eea-8d36-1c0e9e907a22-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/post/60813</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/60813</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Mon, 10 Mar 2025 07:03:58 GMT</pubDate></item></channel></rss>
