<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Route Calculation in Offline Mode]]></title><description><![CDATA[<p dir="auto">Hello everyone.</p>
<p dir="auto">Am I missing something in my set up or does the App not calculate a route when in Offline Mode?</p>
<p dir="auto">I have all the maps downloaded locally to my Android OS tablet.  Tried calculating a route between 2 towns and the app said based on my installed maps it can't do it in Offline Mode that I needed to switch to online.</p>
<p dir="auto">I keep the App and the Maps updated anytime it tells me there's a new update so I don't believe that is the issue.</p>
<p dir="auto">Like a lot of you I ride a lot with no cell service and being able to get directions with no cell service is very important to me.</p>
]]></description><link>https://forum.myrouteapp.com/topic/8339/route-calculation-in-offline-mode</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 21:10:54 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/8339.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Nov 2024 11:25:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Route Calculation in Offline Mode on Sat, 16 Nov 2024 08:40:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/con-hennekens" aria-label="Profile: Con-Hennekens">@<bdi>Con-Hennekens</bdi></a> They are all downloaded.  The towns are only 45 minutes apart.  I'll try again later and see what It does.</p>
]]></description><link>https://forum.myrouteapp.com/post/56959</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56959</guid><dc:creator><![CDATA[PatsAdventuresTravels]]></dc:creator><pubDate>Sat, 16 Nov 2024 08:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to Route Calculation in Offline Mode on Fri, 15 Nov 2024 08:26:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/patsadventurestravels" aria-label="Profile: PatsAdventuresTravels">@<bdi>PatsAdventuresTravels</bdi></a>, there should be no problem doing that offline, of all needed map regions are downloaded.</p>
]]></description><link>https://forum.myrouteapp.com/post/56944</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56944</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Fri, 15 Nov 2024 08:26:08 GMT</pubDate></item><item><title><![CDATA[Reply to Route Calculation in Offline Mode on Thu, 14 Nov 2024 15:21:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marinus-van-deudekom" aria-label="Profile: Marinus-van-Deudekom">@<bdi>Marinus-van-Deudekom</bdi></a> I was at lunch and just told it to find me the fastest route from where I currently was to the town I wanted to go to.</p>
]]></description><link>https://forum.myrouteapp.com/post/56935</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56935</guid><dc:creator><![CDATA[PatsAdventuresTravels]]></dc:creator><pubDate>Thu, 14 Nov 2024 15:21:44 GMT</pubDate></item><item><title><![CDATA[Reply to Route Calculation in Offline Mode on Thu, 14 Nov 2024 15:20:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bouke-ent" aria-label="Profile: Bouke-Ent">@<bdi>Bouke-Ent</bdi></a> I just told it to find me the fastest route between the town I was in to the town I was going.  Not a specific address.</p>
<p dir="auto">For example I was in Wellington Ohio and wanted to go to Marshallville Ohio and just wanted the fastest route.</p>
<p dir="auto">I could have gotten there without navigation if I needed to but I wanted to see the fastest route.</p>
]]></description><link>https://forum.myrouteapp.com/post/56934</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56934</guid><dc:creator><![CDATA[PatsAdventuresTravels]]></dc:creator><pubDate>Thu, 14 Nov 2024 15:20:51 GMT</pubDate></item><item><title><![CDATA[Reply to Route Calculation in Offline Mode on Thu, 14 Nov 2024 12:38:33 GMT]]></title><description><![CDATA[<p dir="auto">what kind off calc do you use. i can be wrong but only direct a to b works offline. also recalc only works on a route. all track options use online calculation.</p>
]]></description><link>https://forum.myrouteapp.com/post/56923</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56923</guid><dc:creator><![CDATA[Bouke Ent]]></dc:creator><pubDate>Thu, 14 Nov 2024 12:38:33 GMT</pubDate></item><item><title><![CDATA[Reply to Route Calculation in Offline Mode on Thu, 14 Nov 2024 11:55:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/patsadventurestravels" aria-label="Profile: PatsAdventuresTravels">@<bdi>PatsAdventuresTravels</bdi></a> Hi<br />
Of you make a new route like you did between 2 City s, you need to be online to get that new route cyncronised with your tablet. After you've done that you can return to offline navigating</p>
]]></description><link>https://forum.myrouteapp.com/post/56922</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56922</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Thu, 14 Nov 2024 11:55:02 GMT</pubDate></item></channel></rss>
