<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Skipping Waypoints....]]></title><description><![CDATA[<p dir="auto">When skipping waypoints, it would be better to see what the waypoint is called rather than just a number.<br />
I rename most of my waypoints. It would be nice to also see what the name of the next approaching waypoint is rather than just a number.</p>
]]></description><link>https://forum.myrouteapp.com/topic/8331/skipping-waypoints</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 22:52:12 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/8331.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Nov 2024 09:38:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Skipping Waypoints.... on Tue, 12 Nov 2024 19:52:18 GMT]]></title><description><![CDATA[<p dir="auto">I tend to agree with <a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-q" aria-label="Profile: Simon-q">@<bdi>Simon-q</bdi></a> having the point name in any popup/notification would be a lot more informative than just a number.<br />
Distinguishing between via &amp; shaping points in this regard is IMO a nonsense, they are all points &amp; should be treated the same, making a distinction just adds useless complexity.</p>
<p dir="auto">What I also think would be useful &amp; might make the numbers a bit more meaningful is if the option to "Show Next Waypoint Information" actually did what it says.<br />
<img src="/assets/uploads/files/1731440728236-f4f3cb37-bf53-46ce-9956-a614892e16c0-image.png" alt="f4f3cb37-bf53-46ce-9956-a614892e16c0-image.png" class=" img-fluid img-markdown" /><br />
At present I believe this option only shows the point information when within a certain distance of the point.<br />
If the point name was shown immediately after the previous point was passed, then the user would have time &amp; maybe able to associate this point name with the number on the waypoint/skip button.</p>
<p dir="auto">If the user selects to see the next point name show it to them, don't hide it with some hidden filter. IMO this is a poor design choice.</p>
]]></description><link>https://forum.myrouteapp.com/post/56909</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56909</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Tue, 12 Nov 2024 19:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Tue, 12 Nov 2024 09:14:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/herman-veldhuizen" aria-label="Profile: Herman-Veldhuizen">@<bdi>Herman-Veldhuizen</bdi></a> said in <a href="/post/56874">Skipping Waypoints....</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-q" aria-label="Profile: Simon-q">@<bdi>Simon-q</bdi></a> I agree with you. One can always give a point the name of the number if one wants too. So the user decide. For example : Point 3 can have the name "3".</p>
</blockquote>
<p dir="auto">That does not work for dynamic numbering of waypoints... What if you add a WP in between others? Waypoints will always have a number to define the order.</p>
]]></description><link>https://forum.myrouteapp.com/post/56888</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56888</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Tue, 12 Nov 2024 09:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 22:41:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: Rob-Verhoeff">@<bdi>Rob-Verhoeff</bdi></a> said in <a href="/post/56865">Skipping Waypoints....</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-q" aria-label="Profile: Simon-q">@<bdi>Simon-q</bdi></a> I don’t have that need at all. Shaping points are only meant to shape your route so that you follow exactly the path that’s needed. If I ever wanted to rename a route point, it would always be a via point and never a shaping point.</p>
</blockquote>
<p dir="auto">I never mentioned shaping points....just waypoints. Sometimes you don't need to visit them.</p>
]]></description><link>https://forum.myrouteapp.com/post/56877</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56877</guid><dc:creator><![CDATA[Exrm193]]></dc:creator><pubDate>Mon, 11 Nov 2024 22:41:46 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 14:48:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: Rob-Verhoeff">@<bdi>Rob-Verhoeff</bdi></a> said in <a href="/post/56867">Skipping Waypoints....</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bikerlou" aria-label="Profile: Bikerlou">@<bdi>Bikerlou</bdi></a> said in <a href="/post/56866">Skipping Waypoints....</a>:</p>
<blockquote>
<p dir="auto">The terminology is always confusing - waypoints vs via points vs shaping<br />
points</p>
</blockquote>
<p dir="auto">Confusing? What’s confusing about it then? The terms don’t seem open to multiple interpretations to me! A shaping point is used to shape your route, while a via point is a location you always want to visit along your route. What’s so difficult about that?</p>
</blockquote>
<p dir="auto">I can see why some people get confused with terminology if they have used other apps in the past. Scenic uses the term “via” for what MRA calls a shaping point, and “stop” for what MRA calls “via”. Garmin themselves even used to have different terminology before they changed some years ago.</p>
<p dir="auto"><a href="https://forums.garmin.com/apps-software/mac-windows-software/f/basecamp-windows/159083/pois-waypoints-via-points-shaping-points-101" rel="nofollow ugc">https://forums.garmin.com/apps-software/mac-windows-software/f/basecamp-windows/159083/pois-waypoints-via-points-shaping-points-101</a></p>
]]></description><link>https://forum.myrouteapp.com/post/56871</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56871</guid><dc:creator><![CDATA[Dae 0]]></dc:creator><pubDate>Mon, 11 Nov 2024 14:48:07 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 14:39:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-q" aria-label="Profile: Simon-q">@<bdi>Simon-q</bdi></a> I agree with you. One can always give a point the name of the number if one wants too. So the user decide. For example : Point 3 can have the name "3".</p>
]]></description><link>https://forum.myrouteapp.com/post/56874</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56874</guid><dc:creator><![CDATA[Herman Veldhuizen]]></dc:creator><pubDate>Mon, 11 Nov 2024 14:39:34 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 14:04:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: Rob-Verhoeff">@<bdi>Rob-Verhoeff</bdi></a>, I can think of many reasons why I would rename a shaping point (I often do). I see no reason why to limit some functionality to shaping points. In fact I think it is more work to limit something, than to generally make it available. The sole difference between shaping points and via points is their auto-skip behavior (and please keep it like that!) <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--wink" style="height:1.4em;width:auto;vertical-align:middle" title=";-)" alt="😉" /></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-q" aria-label="Profile: Simon-q">@<bdi>Simon-q</bdi></a>, to be honest, I think your suggestion is a bit stretching the screen estate in the app. Often WP names are really long, and in by far most cases senseless addresses. So generically showing all waypoint names is not a good idea I think.</p>
<p dir="auto">Are you aware of the fact that, when a WP (Yes Rob, Shaping as well as via points! <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--wink" style="height:1.4em;width:auto;vertical-align:middle" title=";-)" alt="😉" /> ) contains a note, the name and the note are displayed by a single tap on the waypoint?</p>
<p dir="auto">In my opinion your suggestion could lead to two (probably rather easy) improvements:</p>
<p dir="auto">A)<br />
<img src="/assets/uploads/files/1731333577246-2d6e38d1-15df-4bfa-8310-e1bd877efef5-image.png" alt="2d6e38d1-15df-4bfa-8310-e1bd877efef5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This picture shows a single tap on a waypoint with a note (or a picture). On this info field a button "continue from this waypoint" could be added. More than enough space!</p>
<p dir="auto">B)<br />
<img src="/assets/uploads/files/1731333783583-b1e58750-f156-4694-920b-f23bac063de7-image.png" alt="b1e58750-f156-4694-920b-f23bac063de7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This picture shows a long press on a waypoint. The information about the waypoint could be completed with the name and the note of this waypoint.</p>
<p dir="auto">Would that suffice in your view?</p>
]]></description><link>https://forum.myrouteapp.com/post/56870</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56870</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Mon, 11 Nov 2024 14:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 12:24:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: Rob-Verhoeff">@<bdi>Rob-Verhoeff</bdi></a><br />
I do agree with Rob. The terminology is quite clear but not everyone has it in sharp focus. And as for skipping points; please let it remain numeric; Then it will continue to correspond to the numeric points as they appear on the map. And please let sit also remain numeric for clarity.</p>
<p dir="auto">Ik ben het wel met Rob eens. De terminologie is best  duidelijk maar niet iedereen heeft deze scherp voor ogen.<br />
En voor wat betreft het skippen van punten; laat het a.u.b. numeriek blijven; Dan blijft het overeen komen met de numerieke punten zoals deze op de kaart staan. En laat sit ook graag numeriek blijven voor de overzichtelijkheid.</p>
]]></description><link>https://forum.myrouteapp.com/post/56868</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56868</guid><dc:creator><![CDATA[a white mouse on the motorbike]]></dc:creator><pubDate>Mon, 11 Nov 2024 12:24:51 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 11:45:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bikerlou" aria-label="Profile: Bikerlou">@<bdi>Bikerlou</bdi></a> said in <a href="/post/56866">Skipping Waypoints....</a>:</p>
<blockquote>
points</p>
</blockquote>
<p dir="auto">Furthermore, I really don’t understand you guys (no offense!). Besides, the space for that box is too limited to display a full name as you want, I think. But anyway, different people, different preferences...</p>
]]></description><link>https://forum.myrouteapp.com/post/56867</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56867</guid><dc:creator><![CDATA[Rob Verhoeff]]></dc:creator><pubDate>Mon, 11 Nov 2024 11:45:32 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 10:58:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: Rob-Verhoeff">@<bdi>Rob-Verhoeff</bdi></a><br />
I'm with Simon - I use via points more than shaping points as I  find them a more reliable way to ensure I follow my chosen route, and I also use them to add notes/names, so that I know where I am! I would also find it very helpful to know the name of the 'via' point. (The terminology is always confusing - waypoints vs via points vs shaping<br />
points)</p>
]]></description><link>https://forum.myrouteapp.com/post/56866</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56866</guid><dc:creator><![CDATA[Bikerlou]]></dc:creator><pubDate>Mon, 11 Nov 2024 10:58:52 GMT</pubDate></item><item><title><![CDATA[Reply to Skipping Waypoints.... on Mon, 11 Nov 2024 10:28:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simon-q" aria-label="Profile: Simon-q">@<bdi>Simon-q</bdi></a> I don’t have that need at all. Shaping points are only meant to shape your route so that you follow exactly the path that’s needed. If I ever wanted to rename a route point, it would always be a via point and never a shaping point.</p>
]]></description><link>https://forum.myrouteapp.com/post/56865</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/56865</guid><dc:creator><![CDATA[Rob Verhoeff]]></dc:creator><pubDate>Mon, 11 Nov 2024 10:28:48 GMT</pubDate></item></channel></rss>
