<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Increase display size of speed limit and speed in Android Auto/Car Play?]]></title><description><![CDATA[<p dir="auto">Suggestion - am sure quite a few of us are in reading glasses! as we get older.</p>
<p dir="auto">I am using a 7" Andoid Auto/Carplay screen and using this with MRA Navigation Next is excellent. Only issue is the speed limit and speed I am travelling in top right of screen is not that readable if you have poorer near vision eye sight, but also even with good eyesight a glance at it is difficult to read. (I am reporting this from an Anrdroid user - not sure if same issue with CarPlay?).</p>
<p dir="auto">Suggest - would it be possible in settings on device to be able to increase size of the Speed limit and your speed objects so user can increase them (especially if they are using larger Android Auto/Car Play units.</p>
<p dir="auto">Apart from this the improvements for Android Auto in the 4.1.3 version are brilliant, keep up the excellent work.</p>
]]></description><link>https://forum.myrouteapp.com/topic/6984/increase-display-size-of-speed-limit-and-speed-in-android-auto-car-play</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 08:40:27 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/6984.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 May 2024 12:21:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Increase display size of speed limit and speed in Android Auto/Car Play? on Mon, 20 May 2024 13:48:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-smith" aria-label="Profile: Rob-Smith">@<bdi>Rob-Smith</bdi></a>!</p>
<p dir="auto">I know that the speed limit is a anise feature for most of the days navigation systems, but my personal opinion is, that it might be a good idea to remove them from the displays, as no map material or any other data source can be as accurate and up to date as it is needed for us driver to use them seriously. They are often misleading and they increase the risk to be speeding because we use this data from the navigation system.</p>
<p dir="auto">I understand your request.</p>
<p dir="auto">Greetings<br />
Tom</p>
]]></description><link>https://forum.myrouteapp.com/post/46956</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/46956</guid><dc:creator><![CDATA[TomOnTour]]></dc:creator><pubDate>Mon, 20 May 2024 13:48:08 GMT</pubDate></item></channel></rss>
