<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Een veerpond oversteken .]]></title><description><![CDATA[<p dir="auto">De route is gemaakt ,ook over bv de maas..<br />
Via Veerpond<br />
Met Garmin  en Tom Tom geen probleem.<br />
Maar met Navigation gaat het mis.<br />
Dan verlegt Navigation de route via een brug.<br />
En dat is niet de bedoeling.<br />
Gr Jan</p>
]]></description><link>https://forum.myrouteapp.com/topic/1921/een-veerpond-oversteken</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 00:16:22 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/1921.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Feb 2022 20:26:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Een veerpond oversteken . on Fri, 22 Jul 2022 10:15:46 GMT]]></title><description><![CDATA[<p dir="auto">Very interesting post, thank you.</p>
]]></description><link>https://forum.myrouteapp.com/post/14787</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/14787</guid><dc:creator><![CDATA[KennetSBurke 0]]></dc:creator><pubDate>Fri, 22 Jul 2022 10:15:46 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Tue, 08 Feb 2022 14:38:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan-tomassen" aria-label="Profile: jan-tomassen">@<bdi>jan-tomassen</bdi></a><br />
Klopt Jan, het zit hem in de kaartgegevens.</p>
]]></description><link>https://forum.myrouteapp.com/post/11625</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11625</guid><dc:creator><![CDATA[HABVEN aka MrMRA]]></dc:creator><pubDate>Tue, 08 Feb 2022 14:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Tue, 08 Feb 2022 08:29:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan-tomassen" aria-label="Profile: jan-tomassen">@<bdi>jan-tomassen</bdi></a> said in <a href="/post/11599">Een veerpond oversteken .</a>:</p>
<blockquote>
<p dir="auto">'t Blijft een dingentje dat toch opgelost zou moeten worden.</p>
</blockquote>
<p dir="auto">Dit staat buiten kijf, en zal hopelijk bij de eerstvolgende roadmap duidelijk worden.</p>
<p dir="auto">Voor nu gebruik ik de onderstaande methode zoals we allemaal hier ook op enige vorm beschrijven:<br />
<img src="/assets/uploads/files/1644308418100-319785a1-2ad3-4410-8fa3-681afd25d6a2-image.png" alt="319785a1-2ad3-4410-8fa3-681afd25d6a2-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Een viapunt (hand) aan de ene kant van de veerpond, en een normaal routepunt aan de overkant die op skip/offroad staat voor correcte routeplanning in de routeplanner.<br />
Als je gaat rijden zal je zien dat de navigatie in het route overzicht jou niet over de pond wil laten navigeren, maar in de praktijk maakt dat niets uit, omdat de navigatie sowieso eist dat je door in dit geval viapunt 2 rijdt, en dan sta je al op de pond.</p>
<p dir="auto">Vervolgens kunnen er twee dingen gebeuren die ik in de praktijk met MRA nav heb gezien:</p>
<ul>
<li>De navigatie blijft je willen omleiden naar routepunt 3, en dus niet over de pond. Dat blijft hij net zo lang doen tot je wel door routepunt 3 heen rijdt, en daar kom je vanzelf als je de instructie gewoon negeert, want de pond brengt je naar routepunt 3. (even aangenomen dat je Routepunten Automatisch Overslaan neit aan hebt staan, zo wel, dan moet je de meldingen even wegklikken om te voorkomen dat je routepunt 3 verliest).</li>
<li>MRA Navigatie herkent nu ineens de pond wel als rijdbare overgang nu je er vlak voor staat, en zal je gewoon over de pond navigeren... ook al heeft dat weinig nut want je staat al voor de pond door de slimme plaatsing van viapunt 2.</li>
</ul>
<p dir="auto">Eenmaal aan de overkant van de pond pakt MRA alles gewoon weer op omdat je namelijk door routepunt 3 kan rijden.</p>
<p dir="auto">Wat met deze omweg wel irritant is en overkomenlijk blijkt, is dat de verwachte aankomst tijd door deze artificiele incorrecte pondvermijdendekronkel niet meer correct is, tot je de pond hebt doorgemaakt.</p>
]]></description><link>https://forum.myrouteapp.com/post/11602</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11602</guid><dc:creator><![CDATA[Stefan Hummelink]]></dc:creator><pubDate>Tue, 08 Feb 2022 08:29:09 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Tue, 08 Feb 2022 07:17:40 GMT]]></title><description><![CDATA[<p dir="auto">@hans-van-de-ven-mra-master<br />
Het viapunt is wel de oplossing voor myrouteapp.<br />
Maar voor Navigation nog niet.<br />
't Blijft een dingentje dat toch opgelost zou moeten worden.<br />
Gr Jan</p>
]]></description><link>https://forum.myrouteapp.com/post/11599</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11599</guid><dc:creator><![CDATA[jan tomassen]]></dc:creator><pubDate>Tue, 08 Feb 2022 07:17:40 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Tue, 08 Feb 2022 05:15:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan-tomassen" aria-label="Profile: jan-tomassen">@<bdi>jan-tomassen</bdi></a></p>
<p dir="auto">Hallo Jan, maak van het punt waar je de veerboot op gaat een viapunt, daar brengt de navigatie je naartoe.<br />
En als je het opvolgende routepunt overslaat, gaat het in de planner ook goed</p>
]]></description><link>https://forum.myrouteapp.com/post/11598</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11598</guid><dc:creator><![CDATA[HABVEN aka MrMRA]]></dc:creator><pubDate>Tue, 08 Feb 2022 05:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Mon, 07 Feb 2022 22:16:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: rob-verhoeff">@<bdi>rob-verhoeff</bdi></a> beide apps zijn ook van MRA, alleen de MRA Navigation app, waar TS mee wenst te rijden (volgens zijn eerste bericht), herkent nog niet het onderscheid in de routepunten dat in de MRA Routeplanner, aan te brengen is, en dat is bagger want zo kan je toch niet geheel zonder kanttekeningen en uitzonderingen de route met MRA Navigation rijden.</p>
<p dir="auto">Daarnaast zou je ook verwachten dat alle nieuwe functies in MRA Routeplanner ook direct in MRA Navigation zouden werken aangezien hetzelfde bedrijf er aan ten grondslag ligt, maar ook dit is in de praktijk een stuk weerbarstiger. <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--disappointed" style="height:1.4em;width:auto;vertical-align:middle" title=":(" alt="😞" /></p>
]]></description><link>https://forum.myrouteapp.com/post/11594</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11594</guid><dc:creator><![CDATA[Stefan Hummelink]]></dc:creator><pubDate>Mon, 07 Feb 2022 22:16:43 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Mon, 07 Feb 2022 22:09:31 GMT]]></title><description><![CDATA[<p dir="auto">@stefanhummelink ik ga er vanuit dat men gebruikmaakt van "Routelab"... en ja, ik noem alles MRA omdat dat ook prominent linksboven op de website wordt genoemd "MRA Routeplanner" <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--wink" style="height:1.4em;width:auto;vertical-align:middle" title=":wink:" alt="😉" /><br />
Edit: overigens zit de optie "Overslaan" ook in de App-versie van MRA!</p>
]]></description><link>https://forum.myrouteapp.com/post/11593</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11593</guid><dc:creator><![CDATA[Rob Verhoeff]]></dc:creator><pubDate>Mon, 07 Feb 2022 22:09:31 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Mon, 07 Feb 2022 21:40:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob-verhoeff" aria-label="Profile: rob-verhoeff">@<bdi>rob-verhoeff</bdi></a> Deze optie werkt niet in MRA Navigation omdat Navigation in de huidige versie geen onderscheid maakt tussen de verschillende type routepunten... In de planner werkt deze optie natuurlijk wel, maar in nav niet.</p>
<p dir="auto">Meermaals aangekaart bij MRA, maar tot op heden nog niet opgelost.</p>
]]></description><link>https://forum.myrouteapp.com/post/11592</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11592</guid><dc:creator><![CDATA[Stefan Hummelink]]></dc:creator><pubDate>Mon, 07 Feb 2022 21:40:27 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Mon, 07 Feb 2022 21:38:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan-tomassen" aria-label="Profile: jan-tomassen">@<bdi>jan-tomassen</bdi></a> Er is een speciale optie in MRA. "Routepunt overslaan". Plaats een punt waar je de pont oprijdt en plaats een punt waar je de pont afrijdt. Dat laatste punt selecteer je en dan kies je voor "Overslaan". MRA zal dan in een rechte lijn navigeren van het laatste punt voor de pont tot het punt na de pont.</p>
]]></description><link>https://forum.myrouteapp.com/post/11591</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11591</guid><dc:creator><![CDATA[Rob Verhoeff]]></dc:creator><pubDate>Mon, 07 Feb 2022 21:38:44 GMT</pubDate></item><item><title><![CDATA[Reply to Een veerpond oversteken . on Mon, 07 Feb 2022 21:26:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jan-tomassen" aria-label="Profile: jan-tomassen">@<bdi>jan-tomassen</bdi></a> Gewoon daadwerkelijk naar de pond rijden, de navigatie zal dan waarschijnlijk alsnog gewoon over de pond gaan, zo niet, dan negeer je de route tot je aan de overkant bent, en daar pakt nav de route weer op. Dit heeft meermaals zo bij mij uitgepakt bij gebruik van MRA Navigation.</p>
<p dir="auto">Zorg dus even dat in je route twee routepunten strak aan beide zijdes van de overgang staan en niet stukken verderop.</p>
]]></description><link>https://forum.myrouteapp.com/post/11590</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/11590</guid><dc:creator><![CDATA[Stefan Hummelink]]></dc:creator><pubDate>Mon, 07 Feb 2022 21:26:56 GMT</pubDate></item></channel></rss>
